Am vrut sa instalez senzori de parcare pe fata si dupa ce am terminat am vrut sa pornesc masina, dar nu a mai pornit. Va dau o scanare cu VCDS va rog poate cineva sa ma ajute, atasez fisierul cu scanarea. Chassis Type: 8U (8U0) Scan: 01 02 03 08 09 10 15 16 17 19 20 22 25 42 44 46 52 53 55 5F 62 72 VIN: WAUZZZ8U3CR001200 Mileage: 84680km-52617miles 01-Engine -- Status: Cannot be reached 1100 02-Auto Trans -- Status: Cannot be reached 1100 03-ABS Brakes -- Status: Cannot be reached 1100 04-Steering Angle -- Status: Cannot be reached 1100 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 10-Park/Steer Assist -- Status: Cannot be reached 1100 15-Airbags -- Status: Cannot be reached 1100 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 20-High Beam Assist. -- Status: Cannot be reached 1100 22-AWD -- Status: Cannot be reached 1100 25-Immobilizer -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: Cannot be reached 1100 46-Central Conv. -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: Cannot be reached 1100 55-Headlight Range -- Status: Cannot be reached 1100 5F-Information Electr. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000
Pai nu iti comunica cu aproape nici un modul, eu as verifica ECU. Incearca sa deconectezi instalatia senzorilor fata, vezi daca raman erorile. Ceva nu ai facut bine.
Ia-o la verificat in ordine inversa a operatiunilor efectuate pentru montare senzori, poate gasesti/iti dai seama ce ai facut gresit. Ca e clar ca asta s-a intamplat, nu putea sa nu mai porneasca asa din senin. Verifica CAN-ul sau fibra (nu stiu exact ce ai tu), posibil pe partea asta sa fi scos vreo mufa/intrerupt/rupt vreun fir in procesul de montare senzori/cablaje.
