The fuses are located on front left and right of the cockpit and behind the trim on the right side of the luggage compartment. ► Switch the ignition and all electrical equipment off. ► Check the following table to see which fuse belongs to the equipment. ► Remove the appropriate cover. ► Remove the fuse using the clamp. ► Replace the blown fuse only with an identical new one. ► Install the cover. Driver side cockpit fuse assignment Front passenger side cockpit fuse assignment Luggage compartment fuse assignment
Sau mai gasiti localizarea tablourilor cu sigurante din Audi A6 C7 aici: https://www.petenetlive.com/KB/Article/0001161 https://imgvehicle.com/audi/a6-c7/fuse-box
