Codari pentru Audi A6 C8 (4K) >2019 1. Needle Sweep in Virtual Cockpit a. Select Control Module b. 17 – Instruments c. Coding – 07 d. Long Coding Helper e. Byte 1, Check Bit 0 f. Exit Long Coding Helper g. Click “Do It!” 2. Display transmission gear for "D" and "S" drive modes a. Select Control Module b. 02-Auto Trans c. Adaptation – 10 d. Chanel IDE04111-Single Gear Display e. Select from New Value drop-down “D on/S on” f. Click “Do it!” 3. Change the Parking Assist shutdown speed threshold a. Select Control Module b. 09-Cent. Elect. c. Security Access – 16 with security code 20113 d. Adaptation – 10 e. Chanel IDE03782-Switch-off speed for parking assist f. Valoare intre 10 - 20 max 4. Headlights - enable "Off" option a. Select Control Module b. 09-Cent. Elect. c. Coding – 07 d. Long Coding Helper e. Byte 25, Uncheck Bit 3 f. Click “Do It!” 5. DRL (Daytime Running Lights) turn Off in Park a. Select Control Module b. 09-Cent. Elect. c. Coding – 07 d. Long Coding Helper e. Byte 2, Check Bit 2 f. Exit Long Coding Helper g. Click “Do It!” 6. Seat Symmetry + Passenger Seat Control Using Driver Seat Controls a. Select Control Module b. 06–Seat Mem. Pass. and 36-Seat Mem. Drvr. c. Coding – 07 d. Long Coding Helper e. Byte 2, Check Bit 5 f. Byte 6, Check Bit 1 g. Exit Long Coding Helper h. Click “Do It!” 7. Enable Ability to lock the car a. Select Control Module b. 46–Central Conv. c. Coding – 07 d. Long Coding Helper e. Byte 9, Check Bit 7 f. Exit Long Coding Helper g. Click “Do It!” 8. Enable Lap Timer a. Select Control Module b. 17 – Instruments c. Coding – 07 d. Long Coding Helper e. Byte 1, Check Bit 3 f. Exit Long Coding Helper g. Click “Do It!” 9. Daytime Running Lights (DRL) On/Off in MMI a. Select Control Module b. 09-Cent. Elect. c. Coding – 07 d. Long Coding Helper e. Byte 2, Check Bit 1 f. Exit Long Coding Helper g. Click “Do It!” 10. Automatic Lock On/Off setting in MMI a. Select Control Module b. 46-Central Conv. c. Coding – 07 d. Long Coding Helper e. Byte 35, Uncheck Bit 0 f. Exit Long Coding Helper g. Click “Do It!” 11. Automatic Unlock On/Off setting in MMI a. Select Control Module b. 46-Central Conv. c. Coding – 07 d. Long Coding Helper e. Byte 9, Uncheck Bit 1 f. Exit Long Coding Helper g. Click “Do It!” 12. Disabling seatbelt reminder chimes [Select] [17 - Instruments] [Coding - 07] [Long Coding Helper] Click on byte 0 and in bit 4 or 2 [Do It!] 13. Turn on parking brake when selecting Park Select Control Module 03-ABS Security Access - 16 38561 Adaptation - 10 Channel IDE08134 - Automatic parking brake Select Activated Click “Do It!” 14. Change the Parking Assist video shutdown speed threshold Select Control Module A5-Frt Sens. Drv. Assist Adaptation - 10 Channel IDE03782-Switch-off speed for parking assist Enter new value in km/h (I tried 16 kmh, but it came back as 20 on a read, so it might require multiples of 10?) Click “Do It!” 15. DRL Light on rear STG 09 Coding select 11 SL_AT_DRL Set active 16. Dezactivare detectare centura pt AH Selectați STG 03 ajustare Selectați auto_hold_seatbelt_evaluation Ajustați valoarea la dezactivare 17. Activarea luminii pentru traficul pe stânga Selectați STG 09 Coding Selectați mmi_tourist_light Ajustați valoarea la activ O sa mai adaug pe viitor. Codarile le faceti pe propria raspundere.
CarPlay Wireless Activation First - unpair/delete any Apple devices from CarPlay and Bluetooth (including removing the car if already paired from the Apple device itself - setting/general/CarPlay). Module : 5F. (Information Control Unit) Adaptation Vehicle Configuration MirrorLink = On WiFi_Client_HMI = On Apple_DIO_Wireless = On wlan_5ghz_switch = Activated Apple_DIO = On Reboot the MMI by holding down the volume button for 30 odd seconds. Do not plug your Apple device into USB !! Make sure the WIFI hot-spot is turned on in the MMI settings. Pair your Apple device with Bluetooth - it should now ask if you want to enable CarPlay. If it doesn’t, delete the pairing, and connect to the car’s wifi first from the Apple device, and try pairing via Bluetooth again. Mine worked fine first time, and has worked successfully each and every time I’ve entered the car. There's some additional settings for CarPlay under nhtsa_properties, I've not touched any of them, as I have no idea what effect they have.
Ma repet pentru ca vad ca nu intelegeti si tot intrebati aici (oricum mesajele de felul asta sunt sterse direct si fara explicatii) in acest topic: Fara nici un fel de intrebari in topic. Se ataseaza/scriu doar codari, cu VCDS-ul, pe care le faceti pe propria raspundere si atat. Aici in acest topic atasam doar mesaje, fisiere sau filmulete, existente deja cu informatia relevanta si existenta fara sa intrebam cum facem acea codare prezentata sau cum procedam. Nu intrebam cum facem asta, cum codam, cereri de ajutor pentru codari sau mai stiu eu ce alte intrebari. Se scriu doar codari pe care fiecare le face pe propria raspundere si pricepere. Atasez (a mai fost mentionat pe forum) si pentru cei care sunt lenesi = cei care nu sunt in stare sa caute singuri un site: https://www.stemei.de/pages/coding.php care este, poate, cel mai complet catalog pentru codari in grupul VAG. Folositi Google Translate si folositi obligatoriu / de preferat interfeta originala nu clona mizerie chinezeasca. Tineti cont de ce am tot scris pe forum: daca nu va pricepeti apelati cu incredere la profesionisti indiferent de cati km trebuie sa parcurgeti pentru a ajunge la ei. Este de preferat asta in loc sa va transformati voi masinile in niste caramizi nefunctionale din cauza codarilor, parametrizarilor facute gresit / eronat.
