Coding for turning on Audi Active Lane Assist If using OBDEleven use all the directions only on the left half of the "|" symbol, if using VCDS use all the directions on the right side of the "|". UPDATE: Security codes: A5- 20103 ALL Coding: A5 - Frt Sens. Drv. Assist HC>Active | Byte 16>Bit 7 EFP>Active | Byte 12>Bit 3 17 - Dash Board (One of these may already be on, make sure both are) Lane Assistant>Active | Byte 4>Bit 6 Lane Change Assistant>Active | Byte 5>Bit 3 09 - Central Electrics Heading Control Config>heading_control | Byte 35>Bit 0 44 - Steering Assistance Heading Control Assistant>Active | Byte 2>Bit 7 ALL ADAPTATIONS: 5F - Information Electronics Car_Function_Adaptations_Gen2>menu_display_Lane_Departure_Warning = Set Value to “Activated” Car_Function_Adaptations_Gen2>menu_display_Lane_Departure_Warning_over_threshold_high = Set Value to “Activated” Car_Function_List_BAP_Gen2>LDW_HCA_0x19> Set Value to “Activated” Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus> Set Value to “Terminal 15” A5 - Frt Sens. Drv. Assist BAP Personalization = Set Value to “Not Activated” Personalization of lane dept. warning Cl. 15 on = Set value to “Last Setting” System mode, lane depart. warn, = Set Value to “Selection via menu” Switch-on condition, lane depart. warn. = Set value to “On” (I had to toggle this as this is the final step that I believe mimics pressing the button to actually activate it. You know it was successful when the Lane markings show up in the VC)
Fara nici un fel de intrebari in topic. Se ataseaza/scriu doar codari, cu OBDEleven, pe care le faceti pe propria raspundere si atat. Aici in acest topic atasam doar mesaje, fisiere sau filmulete, existente deja cu informatia relevanta si existenta fara sa intrebam cum facem acea codare prezentata sau cum procedam. Nu intrebam cum facem asta, cum codam, cereri de ajutor pentru codari sau mai stiu eu ce alte intrebari. Se scriu doar codari pe care fiecare le face pe propria raspundere si pricepere.
Activare buton Stop Start Clima / Module 08 > Adaptation > channel IDE03253 - A/C comfort parameter for start-stop function > old value: 5 > new value: 0 Low-beam with high-beams Description: Low beams stay on when high beams acƟve. ● 09-Central Electrics ● Long Coding ● Change low_at_flash from “not_active” to “active” ● Press and hold green check mark to accept
PLIERE OGLINZI DIN TELECOMANDA / CHEIE OBDEleven: Comfort System 46 Function : Long Coding Activate byte 20 bit 4
