Restart MMI: Press up on Nav and Radio while pressing on the center wheel Security Codes: 09 - Central Electrics: 20113 13 - Auto Distance Regulation: 20103 6D - Trunk Electric: 12345 57 - TV Tuner: 20103 CA - Sunroof: 20103 Enable Automatic PDC Front: [09 – Central Elect.] [Coding - 07] Select Long Coding Helper Select Bye 37 Check Bit 1 Enable ACC default distance in MMI (might need security code): [13 - Auto Dist. Reg][Adaptation - 10] Select "Distance basic setting option" in dropdown Select "On" from New value drop down Save and reset MMI Enable Laptimer shown in DIS: [17 – Instrument Cluster] [Coding – 07] Select Long Coding Helper Write down coding as backup Select byte 01 Enable bit 03 Increase time required to open trunk lid with remote key: [46 - Central Convenience][Adaptation - 10] Scroll down and find channel "Time for opening rear lid with remote control" Load Stored Value (should be 800 ms) Enter new value in "ms". Example: 2000, Max: 5000 Deactivate seatbelt warning: [17 – Instrument Cluster] [ Adaptation - 10 ] Scroll down to “Deactivate seat belt warning” Stored value should be “No” (Default) Change to “Yes” Do It Enable Needle Sweep: [17 – Instrument Cluster] [Coding – 07] Select Byte 1 Select Bit 0 Tailgate Opening Delay - Via Remote Key Fob: [46 - Central Convenience] [Adaptation - 10] Scroll down and find channel "Time for opening rear lid with remote control" Load Stored Value (should be 800 ms) Enter new value in "ms". Example: 2000 Lock/Unlock "Chirp": [46 - Central Convenience] [Coding - 07] Select Byte 4 Select Bit 6 Adaption Changes for "Chirps" when LOCKING the car: [46 - Central Convenience] [Adaptation - 10] Find channel "(2)-sounder_settings-beeptime_closing_central_locking" Default Value is "single_beep" If you want a single "chirp" when you lock the car, leave this setting as is. If you want a double "chirp" when you lock the car, change the value to "double_beep" Adaption Changes for number of "Indicator Flashes" when LOCKING the car: [46 - Central Convenience] [Adaptation - 10] Find channel "(3)-Turn Signal control-Confirmation flashing locking central locking; flashing cycles" Default Value is "1" If you want a single indicator "flash" when you lock the car, leave this setting as is. If you want a double indiactor "flash" when you lock the car, change the value to "2" Enable "Beep on Unlock": [46 - Central Convenience] [Adaptation - 10] Find channel "(1)-central_locking_system-beep_at_opening" Default Value is "Off" Change Value to "On" Adaption Changes for "Chirps" when UN-LOCKING the car: [46 - Central Convenience] [Adaptation - 10] Find channel "(4)-sounder_settings-beeptime_opening_central_locking" Default Value is "no_beep" If you do NOT want a "chirp" of any sort when you UN-lock the car, leave this setting as is. If you want a single "chirp" when you UN-lock the car, change the value to "single_beep" If you want a double "chirp" when you UN-lock the car, change the value to "double_beep" Adaption Changes for number of "Indicator Flashes" when UN-LOCKING the car: [46 - Central Convenience] [Adaptation - 10] Find channel "(3)-Turn Signal control-Confirmation flashing unlocking central locking; flashing cycles" Default Value is "2" If you want a double indicator "flash" when you UN-lock the car, leave this setting as is. If you want a single indicator "flash" when you UN-lock the car, change the value to "1" If you want a NO indicator "flash" when you UN-lock the car, change the value to "0" DRL (Daytime Running Lights) On/Off Option in MMI: [09 – Central Elect.] [Coding - 07] Select Long Coding Helper Select Byte 2 Select Bit 1 Lock When Driving: [46 - Central Convenience] [Coding - 07] Module 46 - Central Convenience Select Long coding helper Select Byte 35 DE-Select Bit 0 Disable "Low Wind Noise" Stop point on Sunroof: [CA - Sunroof] [Security Access] [Adaption] Find channel "IDE09451-MAS08937-Travel path-Sliding Position: intermed. pos." Value should be "Active" Change to "Not Active" Parking Assist Camera - Turn Off Speed [Module 17 - Instruments] [Adaptation - 10] Scroll down and find channel "Switch off speed for park assist" Load Stored Value (should be set to "10 Kph / 6 Mph") Change to another value. Example "20" (which is about 12 Mph) Enable Ability to lock car with Engine running: [46 - Central Convenience] [Coding - 07] Select Long Coding Helper Select Byte 9 Select Bit 7 De-Activation of Start-Stop(only when AC is on/eco): [08 - Air Conditioning] [Adaptation - 10] A/C comfort param for start/stop function Old Value: 5 New Value: 0 Do It Increase number of flashes when you nudge the stalk: [46 - Central Convenience] [Adaptation - 10] Turn Signal Control => Freeway flashing cycles Change value from 3 to 4 (1-5 possible) Activate rear tail lights with DRL in Auto mode: [09 – Central Elect.] [Coding - 07] Long Coding Long Coding Helper Byte 2 (Third from left) Tick/Select “Bit 3” Exit Do It Automatic Parking Brake: [03 - Brakes] [Adaptation - 10] Automatic Parking Brake -> Activited
Inca o codare interesanta pe care nu am apucat sa o testez - afisaj nivel AdBlue in MMI. In modulul [5F - Information Electronics] trebuie sa existe Menu display adblue active / Menu display adblue over threshold high - active. Dupa codare trebuie resetat MMI.
Reset MMI Press up on Nav and Radio while pressing on the center wheel __________________________________________________ _____________________ Security Codes 09 - Central Electrics: 20113 13 - Auto Distance Regulation: 20103 6D - Trunk Electric: 12345 57 - TV Tuner: 20103 CA - Sunroof: 20103 __________________________________________________ _____________________ Enable Automatic Gear selection shown in DIS [02 – Auto Trans] [Adaptation – 10] Select “Single Gear Display” from top channel drop down menu Select “D on/S on” from New value drop down menu __________________________________________________ _____________________ Enable Automatic PDC Front [09 – Central Elect.] [Coding - 07] Select Long Coding Helper Select Bye 37 Check Bit 1 Long Coding Helper __________________________________________________ _____________________ Enable ACC default distance in MMI (might need security code) [13 - Auto Dist. Reg][Adaptation - 10] Select "Distance basic setting option" in dropdown Select "On" from New value drop down Save and reset MMI __________________________________________________ _____________________ Enable Laptimer shown in DIS [17 – Instrument Cluster] [Coding – 07] Select Long Coding Helper Write down coding as backup Select byte 01 Enable bit 03 __________________________________________________ _____________________ Increase time required to open trunk lid with remote key [46 - Central Convenience][Adaptation - 10] Scroll down and find channel "Time for opening rear lid with remote control" Load Stored Value (should be 800 ms) Enter new value in "ms". Example: 2000, Max: 5000 __________________________________________________ _____________________ Double beep on opening (didn't work on my A4B9 after locking, waiting and unlocking, may need to wait longer) [46 - Central Convenience][Adaptation - 10] Scroll down and find channel "sounder_settings-beeptime_opening_central_locking" change from "no_beep" to "double_beep" __________________________________________________ _____________________ Not sure if this helps Canadian "non-AudiConnect" owner to enable the modem but might be worth a try [5F - Information Electronics][Adaptation - 10] Select "Vehicle configuration-LTE_module" was "activated" in my US A4B9 On the topic of using an external SIM card for data, there is an adaptation channel in 5F called "Internal SIM card; use" with the default setting of "always". Changing this to "automatic" extends the Data Connection Settings menu and allows entering an APN, username and password. The MIB2 detected the required APN automatically based on the SIM card inserted just like older MMI head units. __________________________________________________ _____________________ Enable Sports Computer [17 – Instrument Cluster] [Coding – 07] Select Long Coding Helper Select Byte 10 Enable Bit 2 __________________________________________________ _____________________ Disable Seatbelt Warning [17 – Instrument Cluster] [Coding – 07] Select Long Coding Helper Select Byte 0 Disable Bit 2 __________________________________________________ _____________________ Enable Needle Sweep [17 – Instrument Cluster] [Coding – 07] Select Byte 1 Select Bit 0 __________________________________________________ _____________________ Tailgate Opening Delay - Via Remote Key Fob [46 - Central Convenience] [Adaptation - 10] Scroll down and find channel "Time for opening rear lid with remote control" Load Stored Value (should be 800 ms) Enter new value in "ms". Example: 2000 __________________________________________________ _____________________ Lock/Unlock "Chirp" [46 - Central Convenience] [Coding - 07] Select Byte 4 Select Bit 6 __________________________________________________ _____________________ Adaption Changes for "Chirps" when LOCKING the car: [46 - Central Convenience] [Adaptation - 10] Find channel "(2)-sounder_settings-beeptime_closing_central_locking" Default Value is "single_beep" If you want a single "chirp" when you lock the car, leave this setting as is. If you want a double "chirp" when you lock the car, change the value to "double_beep" __________________________________________________ _____________________ Adaption Changes for number of "Indicator Flashes" when LOCKING the car: [46 - Central Convenience] [Adaptation - 10] Find channel "(3)-Turn Signal control-Confirmation flashing locking central locking; flashing cycles" Default Value is "1" If you want a single indicator "flash" when you lock the car, leave this setting as is. If you want a double indiactor "flash" when you lock the car, change the value to "2" __________________________________________________ _____________________ Enable "Beep on Unlock" [46 - Central Convenience] [Adaptation - 10] Find channel "(1)-central_locking_system-beep_at_opening" Default Value is "Off" Change Value to "On" __________________________________________________ _____________________ Adaption Changes for "Chirps" when UN-LOCKING the car: [46 - Central Convenience] [Adaptation - 10] Find channel "(4)-sounder_settings-beeptime_opening_central_locking" Default Value is "no_beep" If you do NOT want a "chirp" of any sort when you UN-lock the car, leave this setting as is. If you want a single "chirp" when you UN-lock the car, change the value to "single_beep" If you want a double "chirp" when you UN-lock the car, change the value to "double_beep" __________________________________________________ _____________________ Adaption Changes for number of "Indicator Flashes" when UN-LOCKING the car: [46 - Central Convenience] [Adaptation - 10] Find channel "(3)-Turn Signal control-Confirmation flashing unlocking central locking; flashing cycles" Default Value is "2" If you want a double indicator "flash" when you UN-lock the car, leave this setting as is. If you want a single indicator "flash" when you UN-lock the car, change the value to "1" If you want a NO indicator "flash" when you UN-lock the car, change the value to "0" __________________________________________________ _____________________ DRL (Daytime Running Lights) On/Off Option in MMI [09 – Central Elect.] [Coding - 07] Select Long Coding Helper Select Byte 2 Select Bit 1 __________________________________________________ _____________________ Enable ability to Rip CD's to MMI "Jukebox" [5F - Information Electr] [Coding - 07] Select Long coding helper Select Byte 24 Select Bit 5 Adaption: [5F - Information Electr] [Adaptaion - 10] Module 5F - Information Electr Scroll down and find channel "(2)-Copy multimedia data-Optical drive" Load Stored Value (should be set to "Off") Change to "On" __________________________________________________ _____________________ Audi Active Lane Assist - Steering Vibration Adjustment [A5 - Front Sens. Driver Assist] [Adaptation - 10] Scroll down and find channel "IDE05985-Directional stab. assist ; intensity; steering wheel vibration" Load Stored Value (should be set to "Medium") Change to either "Weak / Medium / Strong" __________________________________________________ _____________________ Lock When Driving [46 - Central Convenience] [Coding - 07] Module 46 - Central Convenience Select Long coding helper Select Byte 35 DE-Select Bit 0 __________________________________________________ _____________________ Disable "Low Wind Noise" Stop point on Sunroof [CA - Sunroof] [Security Access] [Adaption] Find channel "IDE09451-MAS08937-Travel path-Sliding Position: intermed. pos." Value should be "Active" Change to "Not Active" __________________________________________________ _____________________ Parking Assist Camera - Turn Off Speed [Adaptation - 10] Scroll down and find channel "Switch off speed for park assist" Load Stored Value (should be set to "10 Kph / 6 Mph") Change to another value. Example "20" (which is about 12 Mph) __________________________________________________ _____________________ Seat Symmetry + Passenger Seat Control **You need to do the SAME coding in Modules 06 and 36.** [06 - Passenger Seat Module][Coding - 07] Select Long coding helper Select Byte 2 Select Bit 5 Select Byte 6 Select Bit 1 [36 - Driver Seat Module][Coding - 07] Select Long coding helper Select Byte 2 Select Bit 5 Select Byte 6 Select Bit 1 __________________________________________________ _____________________ Enable & Pair a Second Phone via Bluetooth simultaneously [5F - Information Electr] [Adaptaion - 10] Scroll down till you find channel "IDE03471-ENG130247-Vehicle configuration-Support_second_phone" (name may be slightly shorter in ODBEleven) Load Stored Value (Default will be "Not Active") Change to "Active" __________________________________________________ _____________________ Enable Ability to lock car with Engine running [46 - Central Convenience] [Coding - 07] Select Long Coding Helper Select Byte 9 Select Bit 7 __________________________________________________ _____________________ Disable rear wiper [09 - Central Electrics] [Coding - 07] Select Long Coding helper Select Byte 12 Set Bit 6 to 0 Set Bit 7 to 1 [09 - Central Electrics] [Coding - 07] Select Long Coding helper Select Byte 12 Select rear_wiper Set value to not_installed __________________________________________________ _____________________ De-Activation of Start-Stop [19 - CAN Gateway] [Adaptation - 10] Start-Stop Voltage Limit>12V (New Value) __________________________________________________ _____________________ Enable Coming home [09 - Central Electrics] [Coding - 07] Select welcome_light Set value to 1 __________________________________________________ _____________________ Activation of automatic opening of the car when approaching The cart opens automatically when you are about 1-2m away. [46 - Central Convenience] [Coding - 07] automatic_opening set to active __________________________________________________ _____________________ Disable side marker [09 - Central Electrics] [Coding - 07] Select Long Coding Helper Select Byte 6 Select Bit 4 [09 – Cent. Elect.] [Coding - 07] Long Coding Helper Select Byte 10 Uncheck Bit 3 __________________________________________________ _____________________ Increase number of flashes when you nudge the stalk [46 - Central Convenience] [Adaptation - 10] Turn Signal Control => Freeway flashing cycles Change value from 3 to 4 (1-5 possible) __________________________________________________ _____________________ Turn off range limiter for Comfort Window System [46 - Central Convenience] Coding->comfort_operation_range_limitation->not active __________________________________________________ _____________________ I haven't done mine, but apparently you can increase the range to lock / unlock. Deactivate Key Lock Range [46 - Central Convenience] Coding->range_limitation_lock-> not active Deactivate Key Opening Range [46 - Central Convenience] Coding->range_limitation_opening-> not active __________________________________________________ _____________________ Increase Steering Wheel Heater Temp **should not go above 38C** [16 - Steering Column Electronics] Adaptation: steering wheel heater __________________________________________________ _____________________ Turns on low beam as well as high beam when you flash people with headlights off [09 - Central Electrics] Coding -> lowbeam_at_flash-> activate __________________________________________________ _____________________ Activate rear tail lights with DRL in Auto mode [09 - Central Electrics] Coding->signiturelight_config-> signaturelight_with_tailight __________________________________________________ _____________________ Enable Emergency braking [46 - Central Convenience] [Coding - 07] Select Long Coding Helper Select Byte 21 Set Bit 0 to 1 If ACC and Pre-sense Set Bit 2 to 1 Set Bit 3 to 1 Select Byte 36 Set Bit 0 to 1 Set Bit 1 to 1 (for hazards to flash) __________________________________________________ _____________________ Combine the park assist 360 camera view with the OPS (Optical Parking Sensors) In the display [17 - Instruments][09 - Central Electronics] [Adaptation - 10] IDE01170-Visual display for park assist Original Value - with OPS display New Value - with OPS 360° __________________________________________________ _____________________ Change ventilated seat cooling fan speeds for each of the 3 setting **Max increase is 10% over the default setting** [09 - Central Electronics] [Adaptation - 10] IDE10322-MAS01366-Seat ventilation; micro adjust.-Stage 3 Stored value 0 % New Value - 10% IDE10322-MAS01365-Seat ventilation; micro adjust.-Stage 2 Stored value 0 % New Value - 10% IDE10322-MAS01364-Seat ventilation; micro adjust.-Stage 1 Stored value 0 % New Value - 10% __________________________________________________ _____________________ Change the Heated Seats temp in each stage **5 DEGREES + OR - IS MAX VALUE** [09 - Central Electronics] [Adaptation - 10] IDE10321-MAS01364-Seat heater: micro adjust.-Stage 1 Stored value 0 °C IDE10321-MAS01364-Seat heater: micro adjust.-Stage 2 Stored value 0 °C IDE10321-MAS01364-Seat heater: micro adjust.-Stage 3 Stored value 0 °C __________________________________________________ _____________________ C to display SQ7 dials In module 17 go into long coding Then change vehicle variant to "derivative 2" Apply changes Come out of long coding Choose reset Then hard reset MMI startup screen to display SQ7 logo: in module 5F long coding, change "byte_18_Screenings" from 27 to 28, reboot MMI __________________________________________________ _____________________ Automatic Parking Brake [03 - Brakes] [Adaptation - 10] Automatic Parking Brake -> Activited
Am activat aseara Enable Ability to lock car with Engine cu Odis, pe VCDS nu imi gaseste modulul 46 Central Convenience
Salutare! Sunt deținătorul unui A4 b9 2.0tdi 150hp manual și acum ceva timp eu cu un prieten m-am jucat pe codarile mașinii mai exact am dezactivat sunetul centurii,am activat needle sweep și am mai dezactivat și spălătorul de faruri toate făcute pe vcds. Toate bune și frumoase până cand ne-am băgat nasul cam mult și din greșeală lui(că eu nu știam să umblu pe vcds) mi-a resetat toate dotările mașinii și au început toți martorii din bord sa se aprindă inclusiv check-engine. Eu nu îmi dădeam seama ce se întâmplă dar el și-a dat seama intr-un final și mi-a recunoscut greșeală. Am incercat sa remediem tot ce mi.a stricat și am găsit coduri de pe alte forumuri din afara dar nici unul din ele nu se potrivesc pe mașina mea( mai exact codul din vcds 09 cent. elect.) Am incercat 3 coduri că doar atât am găsit și fiecare avea 2 sau 3 dotări lipsa de ex. La un cod nu mergea luminile ambientale și cu hold asist,la altul audi pre sens(frânare in caz de un obstacol te atenționează mai întâi și apoi îți pune el frana) și faza lunga automata nu mai mwrge,iar la momentul de față pe alt cod cu care merg acum nu îmi merg senzorii de parcare și sistemul start-stop. Ce pot să fac sa îmi meargă masina că înainte cu toate dotările ei?? Bănuiesc că ar trebui un cod original de pe alta mașină exact ca a mea. Mai jos va atașez 2 imagini cu codul meu actual. P.S.: La reprezentanta dacă mă duc e posibil sa îmi ceara o căruță de bani că sigur va ieși din garanție abia așteaptă ei asta. Cam atât de povestit dacă are cineva o scanare de la mașină lui sau alte sugestii mi-ar fi de mare folos. Mulțumesc anticipat
Pentru cine intreaba ce inseamna Enable Sports Computer nu iti arata Kw si Nm. Iti arata grafic forta G dar nu functioneaza deoarece nu avem senzorii necesari care se gasesc doar pe versiunea RS. @cosmin gudy in folderul Ross-Tech unde ai instalat programul VCDS trebuie sa ai un folder numit Debug si acolo gasesti mai multe fisiere care contin modificarile efectuate. Sincer nu stiu daca s-a memorat cand voi ati facut resetarea dar merita sa incerci sa te uiti. In fisiere practic iti scrie fiecare recodare facuta pe fiecare adresa de la cum era si cum a devenit, inclusiv data si ora cand a fost facuta. Bafta. LE: Tot in Ross-Tech ai si folderul Scans unde gasesti toate scanarile efectuate. Poti recupera codul original daca ai prima scanare facuta masinii fara nici o modificare.
Cosmin cand te inscrii pe forum nu te apuci sa scrii ci te apuci sa citesti. In viata ta sa nu te mai joci tu cu VCDS-ul pentru asa cum vezi ti-ai transformat masina intr-o "caramida nefunctionala". Despre tot ce ai intrebat tu aici pe forum si unde ai si raspunsul deja scris, trebuia sa stii deja inainte sa te apuci sa faci prostii cu VCDS-ul. Daca nu mai recuperezi din Debug codarile trebuie sa reinitializezi codarile pe masina ta la reprezentanta.
Mulțumesc pt sfaturi SV 23 FBI și cristi într-adevar nu trebuia să mă joc de fapt m-am lăsat influențat de prietenul meu că știe că a mai făcut când de fapt el făcuse pe mașini 2000-2005 și deja nu se mai compara situația am evoluat mult de atunci. Și chiar nu mai este o alta solutie in afara de reprezentanta? Si din debug o sa incerc sper sa găsesc.
Daca nu regasesti informatia in Debug nu ai alta solutie. Fiecare modul de pe masina ta trebuie recodat. Ai atat de multa electronica pe masina incat nu ai cum sa o rezolvi fara codarea On-line cu serverele Audi.
Te duci la Darius la Ploiesti si iti faci un full SVM. Nu costa mult. SVM=software version management. Adica iti compara versiunea de soft si codarile existente cu un etalon al masinii tale existent pe server, iti aduce la zi software-ul din toate modulele masinii si ti le codeaza cum au fost ele de fabrica. Practic masina va fi ca in prima zi din fabrica, cu toate calculatoarele ultima versiune de soft existenta pe server.
Activarea preincalzirii motorului la folosirea incalzirii stationare (incalzire auxiliara - sau "webasto", cum ii zic "baietii") pentru platforma B9: Select STG 18 (auxiliary heating) STG Long coding -> function 07 Byte 0 Deactivate bit 3 Când este livrata masina din fabrică, comportamentul incalzirii stationare este astfel încât doar interiorul este preîncălzit. Supapa N-279 este responsabilă de separarea interiorului de compartimentul motorului. Codarea este utilizată pentru a dezactiva supapa și, astfel, să se propage efectul de încălzire si în circuitul motorului. O sa fac si eu codarea cand reusesc sa pun mana pe o interfata originala, o sa fie folositoare cand vin temperaturile cu mult sub zero, mai ales la motorul de 3L (din considerente de uzura). Astept feedback si de la ceilalti ce vor folosi codarea.
O codare foarte cool pentru dashboard la modelul cu display color intre ceasuri. In mod normal in Navigatia din Dashboard apare doar Compass si directia de deplasare daca mergi spre o adresa introdusa in navigatia din MMI. Cu aceasta setare apare si Google Maps pe dashboard, intre ceasurile de bord. Atasez poze cu setarile si cum arata la final. Spor
Turn on Auto High Beams for Premium Plus Cars Descripon:This enables the high beams to turn on automacally depending on traffic condions. ● Central Electronics (09) →Long Coding → high_beam_functions → Set to ‘head_light_assistant’ ● Front Sensor Driver Assistance System (A5) → Long Coding -> AFS_coding_Light_Assist → Set to ‘High_Beam_Assist’ ● Central Electronics (09) → LongCoding → Set mmi_fla_glw_mxb to ‘active’
