1- Fuse box in the Dashboard driver’s side To access the fuse box located on the driver’s side of the dashboard, open the driver’s door and remove the side dash cover, pushing it. Audi Q5 – 1st generation 8R – Fuse Box Diagram – Dashboard driver’s side Description Fuse panel A – black No. Equipment Amps 1 Dynamic steering 5 3 Homelink 5 5 Climate control 5 6 Right headlight range adjustment 5 7 Left headlight range adjustment 5 8 Vehicle electrical system controls module 1 5 9 Adaptive cruise control 5 10 Shift gate 5 11 Heater washer flu id nozzles 5 12 Climate control 5 13 Cell phone prep 5 14 Airbag 5 15 Terminal 15 25 16 Terminal 15 engine 40 Fuse panel B – brown No. Equipment Amps 1 Automatic dimming interiorrearview mirror 5 2 Clutch sensor 5 3 Fuel pump 25 5 Left seat heating 30 6 Electronic Stabilization Program 10 7 Horn 25 8 Left door window regulator motor 30 9 Wiper motor 30 10 Electronic Stabilization Program 25 11 Left doors 15 12 Rain and light sensor 5 Fuse panel C – red No. Equipment Amps 3 Lumbar support 10 4 Dynamic steering 35 5 Climatized cupholder 10 6 Vehicle electrical system control module 1 35 7 Vehicle electrical system control module 1 20 8 Vehicle electrical system control module 1 30 9 Panorama sunroof 20 10 Vehicle electrical system control module 1 30 11 Panorama sunroof shade 20 12 Convenience electronics 5 2- Fuse box in the Dashboard passenger’s side To access the fuse box located on the passenger’s side of the dashboard, you must have the passenger’s door open and remove the side dash cover. Audi Q5 – 1st generation 8R – Fuse Box Diagram – Dashboard passenger’s side Description Fuse panel A – black No. Equipment Amps 5 Steering column switch module 5 6 Electronic Stabilization Program 5 7 Terminal 15 diagnostic connector 5 8 Gateway 5 Fuse panel B – brown 1 CD /DVD player 5 2 Audi drive select switch module 5 3 MMI/Radio 5/20 4 Instrument cluster 5 5 Gateway 5 6 Ignition lock 5 7 Rotary light switch 5 8 Climate control system blower 40 9 Steering column lock 5 10 Climate control 10 11 Terminal 30 diagnostic connector 10 12 Steering column switch module 5 3- Fuse box in the Luggage Compartment right To access the fuse box located on the luggage compartment you should remove the right side trunk trim and open the fuse cover. Audi Q5 – 1st generation 8R – Fuse Box Diagram – Luggage Compartment right Description Fuse panel A – black No. Equipment Amps 1 Luggage compartment lid control module 30 5 Electromechanical parking brake 5 6 Electronic damping control 15 7 Electromechanical parking brake 30 8 Vehicle electrical system control module 2 30 10 Vehicle electrical system control module 2 30 11 Vehicle electrical system control module 20 12 Terminal 30 5 Fuse panel B – brown No. Equipment Amps 1 Luggage compartment lid control module 30 2 Right front seat heating 15 3 DCDC converter path 1 40 4 DCDC converter path 2 40 7 Electromechanical parking brake 30 9 Right door control module 30 11 Right door control module 15 Fuse panel C – red No. Equipment Amps 1 Rear center console outlet 15 2 Center console front outlet/ climatized cupholder 15 3 Luggage compartment outlet 15 4 Cigarette lighter 15 7 Parking system 7.5 8 Rear wiper 15 9 Electromechanical parking brake switch 5 10 Audi side assist 5 12 Terminal 15 control modules 5 Fuse panel D – black No. Equipment Amps 3 DSP amp lifier, radio 30 4 MMI 7.5 5 Radio/navigat ion/cell phone prep 5 6 Rearview camera 5 7 cell phone prep 5 Fuse and relay box №1 in passenger compartment Fuse and relay box №2 in passenger compartment Fuse and relay box №3 in passenger compartment
Fuse and relay box in engine compartment Fuse box in engine compartment Main fuse box in luggage compartment
