ABS si/sau ESP aprins in bord la A8 D3 - cauze si rezolvari
Discuție în 'Audi A8 D3 (2003 - 2010)' creată de geosan1638, 19 Oct 2008.
  1. geosan1638
    geosan1638 1st Gear Member
    25 Mar 2008
    BUCURESTI
    A8 3.0TDI A4 2.5TDI
    Eroare ABS si ESP la A8, nu mai functioneaza !! :(
    Cred ca am foarte mult ghinion cu masina asta sau poate ca asa de bun este modelul.
    O sa fac un mic rezumat la ce am patit pana acum :
    comnezi volan nefunct.
    Address 16: Steering wheel
    Part No SW: 4E0 910 549 HW: 4E0 953 549
    Component: Lenksäulenmodul H13 0040
    Coding: 0012041
    Shop #: WSC 02311
    1 Fault Found:
    01426 - Controls in Steering Wheel (E221)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 3
    Fault Frequency: 7
    Reset counter: 7
    Mileage: 57192 km
    Time Indication: 0
    Date: 2008.05.19
    Time: 12:44:20
    s-a rezolvat prin schimbarea modulului de control aflat in spatele butonului de volum 120E + TVA
    keyless entry:
    Address 05: Acc/Start Auth.
    Part No SW: 4E0 910 131 HW: 4E0 909 131 C
    Component: FBS AUDID3 H03 0140
    Coding: 0410624
    Shop #: WSC 02311
    Part No: XXXXXXXXXXX
    Component: ELV XXXX
    6 Faults Found:
    00668 - Supply Voltage Terminal 30
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 2
    Fault Frequency: 0
    Reset counter: 23
    Mileage: 56880 km
    Time Indication: 0
    Date: 2008.05.11
    Time: 14:39:42
    00179 - Access/Start Authorization Antenna; Drivers Side (R134)
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 33
    Mileage: 56880 km
    Time Indication: 0
    Date: 2008.05.11
    Time: 20:52:10
    00180 - Access/Start Authorization Antenna; Passenger Side (R135)
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 0
    Reset counter: 33
    Mileage: 56880 km
    Time Indication: 0
    Date: 2008.05.11
    Time: 20:52:10
    00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 33
    Mileage: 56880 km
    Time Indication: 0
    Date: 2008.05.11
    Time: 20:52:10
    00182 - Luggage Compartment Access/Start Authorization Antenna (R137)
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 0
    Reset counter: 33
    Mileage: 56880 km
    Time Indication: 0
    Date: 2008.05.11
    Time: 20:52:10
    00183 - Interior Access/Start Authorization Antenna 1 (R138)
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 2
    Reset counter: 33
    Mileage: 56880 km
    Time Indication: 0
    Date: 2008.05.11
    Time: 20:52:10
    asta s-a rezolvat prin schimbarea modulului 340E piesa + 170E montaj + TVA
    Acum dupa un alt drum in germania unde am schimbat toate astea m-am gandit ca ar fi cazul sa schimb si discurile de frana si sa rezolv si webasto.
    Totul ok, cel putin asa mi-au zis baietii de acolo: webasto era blocat(heater unit locked + no flame), l-au resetat sau ceva de genul si au zis ca e Ok .Am mai dat ceva E si pe discuri si treaba asta cu webasto.Ajung si ii fac o scanare cu vag-ul si ma trezesc cu urmatoarele:
    Address 18: Aux. Heat
    Part No SW: 4E0 910 105 A HW: 4E0 815 069 E
    Component: Heizgeraet H07 0100
    Coding: 0000001
    Shop #: WSC 00000
    1 Fault Found:
    01406 - No Flame
    000 - -
    si cel mai ciudat lucru :
    Address 03: ABS Brakes
    Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
    Component: ESP 5.7 allrad H44 0510
    Coding: 0008357
    Shop #: WSC 27022
    1 Fault Found:
    00003 - Control Module
    014 - Defective
    Stie cineva ce si cum am de facut sa scap de aceste erori ?
    Si sincer nu am avut in viata mea atatea probleme cu o masina si chiar nu m-am asteptat la asa ceva de la un a8.
    Multumesc pt sfaturi.
    Ultima editare: 19 Oct 2008
  2. geosan1638
    25 Mar 2008
    BUCURESTI
    A8 3.0TDI A4 2.5TDI
    Dupa mai multe incercari de a porni webasto am reusit. A scos ft mult fum dar important este ca a pornit.
    Mai ramane problema la ABS.
  3. Audi4ever
    Audi4ever Gold Member
    29 Dec 2007
    AUDI A6 & AUDI Q5
    Vezi cum ai pus rulmenti pentru ca au numai o pozitie la montare astfel incat sa citeasca rotatia ABS-ului.
    Ultima editare de un moderator: 30 Iul 2012
  4. geosan1638
    25 Mar 2008
    BUCURESTI
    A8 3.0TDI A4 2.5TDI
    Nu am verificat asta, dar m-am gandit ca nu trebuie umblat la rulmenti.
    Din cate stiu eu se da jos ertierul si ies discurile, deci nu ar fi nevoie sa ajunga la rulmenti. Nu stiu daca am scris asta dar cu tot cu eroarea asta merge ABS-ul. Un om normal ar ignora eroarea si ar lasa-o asa dar eu nu pot :3sadwalk:. Mai am de incercat sa ii scot bateria sa reporneasca tot. Oricum eu ma bucur ca am rezolvat celelalte erori.
  5. TEFF
    TEFF 5th Gear Member
    26 Ian 2009
    Audi S3, 2.0T, 2007
    Am schimabt discurile si placutele acum 1 saptamana la Augsburg service aici in Bucuresti. discuri si placute brembo exact pentru modelul respectiv de audi. Toate bune si frumoase pana cand in seara asta deodata mi-a aparut o eroare in bord: "ABS/ESP Fault".
    Am resetat computerele de bord dar degeaba. Daca opresc si repornesc masina dispar dar dupa cateva minute reapar. Si partea proasta e ca nu-mi mai functioneaza esp si abs, am facut proba si ma duc ca o sanie. Pana azi nu am avut probleme. Si imi mai da o eroare si la frana de mana. Ca cica nu merge si daca pun frana de mana si e masina pornita nu mai merge sa o decuplez, cica trebuie sa tin apasaata frana de picior, dar o tin apasata si nu o detecteaza...nu stiu ce naiba are. In 3 ani de zile masina nu a avut o problema de genul....
    O sa o duc la porsche buc sa vad ce are...voi ce credeti ? :( :sorry:
    livbylife apreciază asta.
  6. Florin Sandu
    Florin Sandu Banned
    26 Mai 2008
    Audi A8 3.0 TDI QUATTRO, Audi A3 1,6 FSI
    Cam naspa Stefane, si eu am schimbat placutele dar nu am avut nici o problema, dar nu le-am schimbat la Augsburg :)
    daca vrei te trimit la cineva la Porsche Vest, anunta-ma doar si vorbim.
  7. Bogdan.IS
    Bogdan.IS Audi Expert
    6 Sep 2007
    probabil ca nu ti-a montat cum trebuie discurile noi . din ce an e masina ? dute la un service recomandat de cei din bucuresti . ferestete de dealerul audi !!! ca vii cu masina stricata si pleci cu ea si mai stricata .
    Ultima editare: 28 Ian 2009
  8. TEFF
    26 Ian 2009
    Audi S3, 2.0T, 2007
    s-a rezolvat, am fost la service si ei si nu stiu ce senzor la pedala de frana era stricat
  9. slack21 1st Gear Member
    28 Apr 2009
    audi a8
    pana la urma a rezolvat cineva problema asta cu ABS-ul ? ca ma bate si pe mine gandu sa-mi cumpar un A8 dar are aceeasi problema .... proprietarul mi-a spus ca dupa ce-a schimbat discurile si placutele i-a aparut eroarea de ABS
  10. gerard
    gerard 1st Gear Member
    6 Mai 2009
    Audi A8 D2
    naspa situatie
    acelasi lucru lam patit si eu cu senzoru de la ABS numai ca am tot ezitat sa il repar , deoarece odata aparea odata disparea si tot asa pana am avut nevoie de el si m-am oprit intr-un tractor care mia taiat calea . ce teapa am luat
  11. Florian0 1st Gear Member
    30 Iul 2012
    audi a8 2004
    Am un a8, 2004, 4,2 benzina si probleme cu senzorii abs,esp si parking brake care imi apar periodic in bord. Am fost la porsche bucuresti vest si mi-a zis ca trebuie sa schimb tot modulul de abs si ceasurile din bord si ar ajunge toata investitia 14000 ron. Totusi nu cred ca e modulul de abs stricat in totalitate, tind sa cred ca am vreun contact imperfect sau alt senzor pt ca nu mi se aprinde tot timpul. Astept o sugestie, raspuns, numar de telefon al unui electrician,electronist bun.
    Multumesc anticipat !
  12. thinkpad 1st Gear Member
    27 Aug 2010
    Petroșani
    Audi A8 3.0TDi & A5 Sportback 2.0 TFSi
    Probleme frana de mana, ESP si ABS
    Dupa un schimb de placute(spate) la niste baieti care nu au stiut cum sa treaca dimensiunile in calculator ( 3 valoarea maxima cand placutele sunt noi si creste pe masura ce se uzeaza pana la 14, eu bine ei mi-au pus 14 direct) Mia apaut eroarea pe bord cu frana de mana.
    Dupa ceva vreme mea aparut si eroarea ca si cum placutele ar fii uzate, dar din cate stiu masina are senzori doar pe fata unde placutele sunt aproape noi(le-am verificat) deci nu stiu de unde a aparut si aceasta eroare.
    Masina in cauza este un A8 2.0 TDI 2004 170.000 km.
    Erorile ni au disparut nici dupa ce am schimbat valoarea dimensiunii placutelor spate la cea reala si nici dupa ce am repetat tot procedeul de deschidere frane, inchidere si test functionare.
    In legatura au ABS-ul nu stiu de unde apare problema, cateodata se aprinde beculetul pe bord si am niste coduri de eroare pe vagcom, le atasez putin mai jos.
    De ceva vreme Esp-ul se decupleaza singur, in sensul ca ar fii ceva defect, si in acelasi timp suspensia se intareste. Dupa ceva timp isi revine merge ce merge si din nou aceeasi problema.
    Astea ar fii codurile de eroare:
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 4E0 910 401 B HW: 4E0 907 401 B
    Component: 3.0L V6TDI G001AG 0060
    Revision: --H01--- Serial number: AUX3Z0D8150596
    Coding: 0011973
    Shop #: WSC 10192 599 87485
    VCID: 1A31A3CCD584A6E
    4 Faults Found:
    00000 - End of output
    001 - Upper Limit Exceeded - Intermittent
    Freeze Frame:
    RPM: 1638 /min
    Torque: 124.8 Nm
    Speed: 52.6 km/h
    18061 - Please check DTC Memory of ABS Controller
    P1653 - 002 -
    Freeze Frame:
    RPM: 1638 /min
    Torque: 124.8 Nm
    Speed: 52.6 km/h
    Duty Cycle: 16.9 %
    Voltage: 13.60 V
    Bin. Bits: 00101000
    Torque: 253.5 Nm
    Temperature: 87.3°C
    16785 - EGR System
    P0401 - 002 - Insufficient Flow - Intermittent
    Freeze Frame:
    RPM: 1449 /min
    Torque: 89.7 Nm
    Speed: 21.3 km/h
    Duty Cycle: 74.7 %
    Duty Cycle: 20.9 %
    Mass Air / Rev.: 452.4 mg/str
    Duty Cycle: 46.6 %
    Mass Air / Rev.: 252.6 mg/str
    18093 - Powertrain Data Bus
    P1685 - 001 - Implausible Message from Steering Angle Sensor
    Freeze Frame:
    RPM: 0 /min
    Torque: 167.7 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 12.24 V
    Bin. Bits: 00101111
    Bin. Bits: 00000001
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes Labels: 4E0-910-517.lbl
    Component: ESP 5.7 allrad H46 0510
    Coding: 0008357
    Shop #: WSC 00011 000 00000
    VCID: 22419B2CFDD4EEE
    2 Faults Found:
    00778 - Steering Angle Sensor (G85)
    008 - Implausible Signal
    01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
    000 - -
    Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
    Part No SW: 4E0 910 279 H HW: 4E0 907 279 H
    Component: ILM Fahrer H12 0190
    Coding: 0120001
    Shop #: WSC 02313 785 00200
    VCID: 2D5B7810B40A216
    Subsystem 1 - Part No: 4E1 910 113 B
    Component: Wischer WWS D3 H50 0400
    Coding: 00000035
    Shop #: WSC 02313
    1 Fault Found:
    02071 - Local Databus
    014 - Defective - Intermittent
    Freeze Frame:
    Fault Status: 00101110
    Fault Priority: 1
    Fault Frequency: 4
    Reset counter: 11
    Mileage: 171479 km
    Time Indication: 0
    Date: 2012.09.05
    Time: 17:10:30
    Address 53: Parking Brake Labels: 4E0-910-801.clb
    Part No SW: 4E0 910 801 A HW: 4E0 907 801
    Component: EPB AV1C1010 H01 1010
    Revision: AV1C1010
    Coding: 0000221
    Shop #: WSC 00011 888 96745
    VCID: 1D3BA8D0C4AAD16
    3 Faults Found:
    02596 - Rear Brake Pads Worn
    Freeze Frame:
    Fault Status: 01100010
    Fault Priority: 6
    Fault Frequency: 110
    Reset counter: 235
    Mileage: 170064 km
    Time Indication: 0
    Date: 2004.03.25
    Time: 00:34:40
    Freeze Frame:
    Voltage: 10.87 V
    Count: 60
    Freeze Frame:
    Fault Status: 01111000
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 235
    Mileage: 166384 km
    Time Indication: 0
    Date: 2004.03.25
    Time: 00:02:59
    Freeze Frame:
    Voltage: 13.25 V
    Count: 61
    02439 - Right Parking Brake Motor Hall Sensor
    004 - No Signal/Communication - MIL ON
    Freeze Frame:
    Fault Status: 11110100
    Fault Priority: 4
    Fault Frequency: 11
    Reset counter: 202
    Mileage: 170064 km
    Time Indication: 0
    Date: 2004.03.25
    Time: 00:08:31
    Freeze Frame:
    Voltage: 13.46 V
    Count: 95
    Cam asta e tot. Daca ati ami avut probleme asemanatoare sau aceste erori va cer ajutorul.
    Ar mai fii problema cu EGR-ul, nu am observat nici un simptom pana am puso pe tester si nu am gasit inca o rezolvare pentru problema si locad databus unde imi da fault priority 1 deci practic nici nu ar mai trebui sa merg cu masina..
    Ultima editare: 14 Sep 2012
  13. drid
    drid Silver Member
    17 Oct 2008
    Buzău
    Salut. Am si eu problema la un A8 cu modulul abs, eroarea pe tester este 014 modul abs defect, atat imi apare, in bord nu imi ramane becuri aprinse, abs-ul si esp-ul lucreza perfect, numai ca pe tester apare eroarea si nu poate fi stearsa, si la mine odata la mult timp 2-3 saptamani cand opresc masina se aude cum motorasele de pe spate de la frana face un circuit cap coada.
    Cei de la wv audi service imi zic sa fac o adaptare la modulul abs dar pe urma se poate sa se strice de tot adica sa imi apara becul in bord. Ce parere aveti?
  14. Coniac 1st Gear Member
    30 Iun 2014
    Audi a8, 4,2 v8 quattro 2004
    Mi se aprinde ABS si ESP in bord. Are vreo legatura servo adica sa nu functioneze (se intareste cateodata volanul, nu mai lucreaza servo cum trebuie) si nici suspensia nu se ridica.
    Ultima editare de un moderator: 3 Iul 2014
  15. F.Adrian
    F.Adrian 1st Gear Member
    15 Mar 2013
    A8L 3.0 2006
    ABS,ESP si parking brake malfunction
    ABS SYSTEM
    1 Fault Found:
    014 - Defective
    De ceva timp imi apare abs ,esp , si parking brake malfunction. Toate de o data .. Dupa 2-3 min parking brake dispare dar revine dupa 5-6 min :scared2:.aveti idee cam de la ce ar putea fi?
  16. AndreiValentin
    AndreiValentin 4th Gear Member
    28 Sep 2014
    Audi A8 3.0 TDI 2013
    Salut referitor la problemele voastre, problema am intampinat-o si eu in trecut pe A8-ul meu, a mea se manifesta doar cand ploua se aprindea esp ul in bord, se intarea si suspensia si volanul chiar daca eu selectam comfort ea ramanea rigida.
    Aceiasi problema o aveam si cu parking brake cele 3 erori apareau in tandem.
    Solutia a fost simpla la mine, era un contact imperfect pe spate la unu din motorase cand prindea apa dadea semnal implauzibil si de acolo erorile.
    Solutia a fost verificarea contactelor de pe ambele parti spate si degresarea lor cu spray pentru contacte apoi pus inapoi si de atunci merge perfect,au trecut 3 luni iar eroarea nu a mai aparut.
    De asemenea este necesara stergerea erorilor cu vag dupa operatiune.
  17. F.Adrian
    15 Mar 2013
    A8L 3.0 2006
    AndreiValentin Ok, deci imi poti explica mai cu lux de amanunte ce trebuie exact sa desfac si sa curat ? Multumesc. :superman:
  18. isvaly
    isvaly Gold Member
    25 Aug 2009
    A4,A6,A8,Q7,
    ABS SYSTEM
    1 Fault Found:
    014 - Defective
    O am si eu pe vag nu poate fi stearsa Cristi "al bundy" Mi a spus ca si el s-a lovit de problema asta si singura solutie de rezolvare este inlocuirea modului sau update la soft la modul.
    Deci mie nu imi sta aprins nimic pe bord eroare se manifesta doar pe vag
    La pedala se simte ca functioneaza corect .
    Tot dezastru s-a produs de la inlocuirea placutelor la incompetenti.
    Dat fiind faptul ca ABS-ul functioneaza corect si eroarea se manifesta doar pe vag nu mi am batut capul sa caut rezolvarea sa din lipsa de timp insa initial as incerca sa fac update la reprezentanta online cu fabrica la modul . SI daca aceasta procedura nu da rezultate ok dupa as schimba modulul
  19. AndreiValentin
    28 Sep 2014
    Deci din cate mi-a zis baiatul care mi le-a curatat, am stat langa el si mi-a explicat.
    Eroarea apare din cauza contactului imperfect in cel mai probabil caz din cauza franei de mana pentru ca atunci cand se actioneaza frana de mana apasa placutele, aceleasi placute care sunt folosite si la franarea propriu zisa.
    Daca apare o eroare la frana de mana din cauza firelor, contact imperfect sau un defect mecanic al unui motoras se dezactiveaza abs ul si esp ul ca masura de precautie in cazul franarii.
    Trebuie sa verifici intai daca frana de mana iti functioneaza pe ambele parti opresti motorul rogi pe cineva sa traga frana de mana si asculti pe partea stanga sau dreapta si observi daca iti functioneaza ambele motorase,daca da trebuie doar sa desfaci mufele alea si sa le cureti sau sa masori valoare curentului pe fire sa vezi daca nu ai vre-o intrerupere pe ele, chestia asta poti foarte usor sa o vezi in vag ca iti arata voltajul ambelor motorase.
  20. F.Adrian
    15 Mar 2013
    A8L 3.0 2006
    AndreiValentin Ok, o sa verific in prim plan daca modulul functioneaza, dupa care o sa desfac mufele si o sa le curat cu spray de contact.
    Multumesc. O sa postez aici rezultatul.
    Ultima editare de un moderator: 23 Mar 2015
