Carlig remorcare/tractare la A4 B7
Discuție în 'Audi A4 B7 (2005 – 2008)' creată de radu2000v, 4 Aug 2009.
  1. Laru 1st Gear Member
    28 Iul 2018
    Gorj
    Audi a4 bke 2006
    Unde,cum caut?multumesc
  2. audi66
    ws = white
    sw = black
    ro = red
    rt = red
    br = brown
    gn = green
    bl = blue
    gr = grey
    li = purple
    vi = purple
    ge = yellow
    or = orange
    rs = pink
    Trailer socket
    J59 - X-contact relief relay
    J345 - Trailer detector control unit
    J519 - Onboard supply control unit
    S87 - Trailer towing attachment thermal fuse
    S232 - Fuse in fuse holder
    T32b - 32-pin connector, grey, on onboard supply control unit
    U10 - Trailer socket
    86 - Earth connection 1, in rear wiring harness
    A34 - Connection (75x), in dash panel wiring harness
    A146 - Connection (convenience CAN bus, high), in dash panel wiring harness
    A147 - Connection (convenience CAN bus, low), in dash panel wiring harness
    B346 - Connection 1 (75), in main wiring harness
    * - applicable up to model year 2005
    ** - applicable from model year 2006
    *** - applicable up to model year 2006
    **** - applicable from model year 2007
  3. audi66
    ws = white
    sw = black
    ro = red
    rt = red
    br = brown
    gn = green
    bl = blue
    gr = grey
    li = purple
    vi = purple
    ge = yellow
    or = orange
    rs = pink
    Brake light switch, trailer detector control unit, fuse in fuse holder
    D - Ignition/starter switch
    F - Brake light switch
    S14 - Fuse in relay plate fuse holder
    S227 - Fuse in fuse holder
    501 - Screw connection 2 (30), on relay plate
    A2 - Positive connection (15), in dash panel wiring harness
    A18 - Connection (54), in dash panel wiring harness
    A32 - Positive connection (30), in dash panel wiring harness
    A57 - Positive connection 3 (30), in dash panel wiring harness
    Laru daca intrebi ce este ELSA si cum cauti iti spun eu sa mergi de urgenta la un profesionist in electrica auto. Bafta.
  5. Apostol Cosmin
    Apostol Cosmin 1st Gear Member
    29 Mar 2017
    Călărași
    A4 Avant 8E - S-Line- - 2008 , TDI2.0 - 140cp (BPW) PD DPF
  6. Silviu92 1st Gear Member
    6 Aug 2016
    Curtea de Argeș
    Audi A4 B5 1.6 ALZ 2001/ A4 B7 1.8T BFB 2006
    Bună ziua,
    Am montat un carlig de remorcare pe un A4 B7 sedan conform schemelor si diagramelor de montaj existente aici in topic dar am 2 probleme la instalația electrica și anume:
    1. firele rosu/negru, în topic este scris ca acele fire se unesc pe partea stânga (mai multe fire) iar apoi merg în mufa lămpii stângi la pinul 3, dar la mașină mea pinul 3 lipsește în mufa stânga.
    2. firele rosu/alb cum se conectează, mă poate ajuta cineva ? Va mulțumesc.
