DPF = Filtrul Particule si AdBlue - SRC (Selective Catalytic Reduction) la A4 B9
Discuție în 'Audi A4 B9 (2015 - prezent)' creată de harfo_79, 8 Mai 2017.
  1. marcelush
    marcelush Banned
    22 Feb 2016
    AUDI A4, B9, (DETA), S-tronic, 2.0 tdi, 190cp, quattro
    Mulțumesc pentru explicatie
  2. david79 1st Gear Member
    24 Sep 2019
    A4B9 Avant S-Line TDI 190 S-tronic
    Salut
    Astazi, dupa o scanare cu vcds-ul am gasit urmatoarea eroare :
    Address 01: Engine (J623-DETA) Labels:. 04L-907-309-V1.clb
    Part No SW: 04L 906 026 AD HW: 04L 907 309 L
    Component: R4 2.0l TDI H33 1970
    Revision: B1H33---
    Coding: 0A254032236405083408
    Shop #: WSC 06314 790 00001
    ASAM Dataset: EV_ECM20TDI01104L906026AD 001006
    ROD: EV_ECM20TDI01104L906026AD_001.rod
    VCID: 6CD771B7878BFEE6C7-8038
    1 Fault Found:
    21376 - Reductant Metering Module
    P20FE 00 [096] - Malfunction
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 92764 km
    Date: 2020.08.18
    Time: 20:07:12
    Engine speed: 860.00 /min
    Normed load value: 26.7 %
    Vehicle speed: 53 km/h
    Coolant temperature: 83 °C
    Intake air temperature: 70 °C
    Ambient air pressure: 1000 mbar
    Voltage terminal 30: 14.060 V
    Unlearning counter according OBD: 34
    Extern.temp.sens.1 bank 1: raw value: 26.5 °C
    Particle filter outlet temp.sens.1 bank 1: raw value: 204.8 °C
    Pressure sensor for reducing agent: measured pressure: 5235 hPa
    Sensor for reducing agent tank temperature: temperature: 32.4 °C
    Heating circuit 1 for reducing agent metering: activation-Bits 0-7: 0
    Din ce am cautat pe net, codul de eroare ar fi :
    Code: P20FE
    Definition:
    Reductant Metering Unit Performance
    Description:
    This code will set after a refill event (based on fluid level change) and ECM does not see a change in NOx during dosing.
    Diagnosis:
    Check fluid in tank for contamination / Check the Nox Sensor Control Module J583 or Nox Sensor Control Module 2 J881.
    Interpretarea pare a fi corecta ?
    Interesant este ca am completat in urma cu 2500 km cu 20L de Adblue ( non OE ) iar acesta eroare nu era inainte.
  3. Sorin87
    Sorin87 Gold Member
    25 Sep 2008
    Pune Adblue OE si vezi ce se intampla.
  4. marcelush
    marcelush Banned
    22 Feb 2016
    Saptamana trecuta, ma anunta ca nu mai am Adblue (range 2000 km). Zilele trecute m-am dus la Bran. Dupa un drum de 3 ore intre Breaza si Bran, in care am mers numai la relanti cu 20 la ora si blocaje pe DN, mi s-a aprins martorul galben robinet - ca in poza. In manual scrie ca ala e martor pentru sistemul de control al gazelor evacuate, adica un defect care inrautateste calitate gazelor evacuate cu potentiala distrugere a catalizatorului.
    Eu banuiesc ca nu pra si-a facut regenerarea si asta e o posibila cauza. am de gand sa vin pe autostrada maine, mai turat, ca sa o ajut. Voi pune de asemenea si adblue (ma opresc la un magazin si iau adblue OE VW - am vazut ca e vreo 70 lei bidon de 10 L. Daca aceste 2 operatiuni nu rezolva - ma duc la mecanic cu ea.
    Probabil ca atata vreme cat nu am bagat un tester pe ea, nu are rost sa va cer un sfat - dar va tin la curent cu evolutia, zilele astea :)
    Vezi
    Vezi ca este in localitatea Ghimbav reprezentanta Skoda Delcar (este aproape de Bran).
    Cumperi de acolo AdBlue OE. Martorul ala nu s-a aprins din cauza AdBlue. Este alta cauza si o vezi la diagnoza.
  6. marcelush
    marcelush Banned
    22 Feb 2016
    OK - am revenit si cu rezolvarea. Cum banuiam era legat de regenerare. Astazi am venit pe autostrada si i-am dat sa zaca: cutia in S, treapta 7, viteza cat cuprinde, cam 2200 rpm (merci Bobalex). Pe autostrada, la un moment dat mi-a spus sa trag pe dreapta ca nu mai am Adblue si ca motorul nu va mai porni. Am continuat drumul pana acasa, unde, langa blocul meu este un OMV, de unde am cumparat si completat cu 20l de AdBlue TEGEE care respecta norma indicata de AUDI: ISO 22241-1, dupa care am parcat masina acasa si am lasat-o vreo 3 ore
    Pe la ora 17 am plecat spre mecanic - imediat cum am pornit motorul am observat ca a disparut atat eroarea / atentionarea de Adblue, cat si eroarea / martorul ala galben. Mecanicul a pus diagnoza si mi-a confirmat ca aparea o eroarea de lipsa ADBLUE, ceea ce a condus la neputinta de a face regenerare.
    Problema e ca in decurs de o saptamana a sarit de la mesajul "hey - mai ai ADBLUE pt 2000 km" - la mesajul "mai ai AdBlue pentru 1000 km" si imediat dupa asta la mesajul "lipsa ADBLUE / ADBLUE Fault - engine won't start"
    In fine - o plimb maine vreo 200 km - am treaba prin afara orasului daca e sa fie o problema o sa apara si maine, daca nu - inseamna ca asta a fost
    Mihaiu600 și skypee apreciază asta.
  7. djxme200
    djxme200 Silver Member
    31 Ian 2011
    In functie de stilul de condus si regimul de mers cei 2000km se pot "termina" mult mai repede.
    La grupul VAG nu stiu cat de ok este sa completezi pana te atentioneaza, la alt grup concurent au fost ceva probleme din cauza aceasta si nu mai indica corect nr de km ramasi pana cand e obligatorie completarea.
  8. MarianMaxx
    Se poate face si calibrare a nivelului cu VCDS daca se observa ceva nereguli.
  9. adrian2b4u
    adrian2b4u 1st Gear Member
    7 Mar 2010
    AUDI A4 B9 2.0TDI DEUC 90KW 2017
    Imi poate spune cineva daca valorile DPF din poza atasata sunt bune sau rele ?
    Sunt de la un Audi A4 B9 122 cp TDI cutie S-tronic cu 150.000 Km acum in bord.
  10. alexnet
    alexnet 2nd Gear Member
    27 Aug 2018
    Pentru eroarea:
    8621 - Sensor 1 for Exhaust Temp Bank 1 (G235)
    P0544 00 [032] - Circuit Malfunction
    Mi-a aparut pe autostrada si a disparut de la sine, dupa 3-4 km. Nu a mai aparut de atunci, de 200 km.
    Asa face cand e pe ultima suta ?
    Este vorba de senzorul numarul 3 din poza ?
    Este corect codul 04L919529E, pentru cod PR DE5 ?
    Merci.
  11. audi66
    Bucuresti / Italy
    Exact.
    alexnet apreciază asta.
  12. skypee
    skypee 3rd Gear Member
    28 Aug 2017
    Galati
    A4 B9 avant 2.0 TDI 150hp
    Caută valorile de la OiL ash, ca sa vezi gradul de încărcare cu funingine .
  13. Grigoras Heidel Florin 1st Gear Member
    30 Iun 2016
    A 4 AVF 2004
    Am un Audi A4 B9 si de ceva vreme mi-a apărut mesajul că nu mai pornește în 1000 de km cu eroare pe AdBlue. Am verificat tensiunile la modulul AdBlue și toate erau ok. Am demontat calculatorul și am găsit apă în el. Acum trebuie să îl înlocuiesc. Trebuie codat calculatorul ? Se poate face adaptarea cu ObdEleven și dacă da cum?
  14. I0nutz
    I0nutz 1st Gear Member
    15 Dec 2020
    United Kingdom / Romania - Buzau
    A4 B9 , 2.0 tdi , 2017
    Salut tuturor
    Pentru cei cu eroarea la sistemul Adblue - Fault 650 si Cod eroare P20E8 Reductant pressure Low - pentru masina mea a fost urmatoarea rezolvare: am inlocuit rezervorul de adblue si ECU de Adblue + resetare.
    Sper sa fie de ajutor pentru cei ce au problema asta
    Bafta
  15. MarianMaxx
    Eu am inlocuit doar pompa de AdBlue. De vina ar fi fost senzorul care citeste presiunea, dar cum vin impreuna, asta este!
  16. alexnet
    27 Aug 2018
    Salut! E pe duca senzorul de presiune?
    Codul de piesa este 04L906051K pentru WAUZZZF44GA006669?
    Daca nu ai erori la diagnoza de ce cauti probleme acolo unde nu sunt ? Il schimbi cand "o sa iti spuna el" singur asta.
    djxme200 apreciază asta.
  18. nelfurdui
    nelfurdui 1st Gear Member
    5 Aug 2018
    Hunedoara
    Audi A4 B9 Avant 2.0 TDI Quattro S-Line 2016
    Salut
    Exact aceiasi eroare o am si eu, se pare ca nu este apa in el, ci este chiar adblue, din cauza ca este montat intr-o locatie unde exista posibilitatea sa curga AdBlue pe el. Ai reusit sa rezolvi problema ? Care e codul calculatorului, cumva 4M0907355D ?
    Urmeaza sa merg la service saptamana viitoare, sa vad ce zic acolo.
  19. kimdiesel
    kimdiesel 2nd Gear Member
    14 Iun 2019
    A4, 2.0 TDI, 2016, cod motor DETA
    Mi-a aparut mesajul sa completez cu AdBlue (2.400 km). Am completat a doua zi cu 20 Litri OE de la VW, cand mai aveam lichid in rezervor pentru inca 2.300 km.
    Nu am avut niciun led aprins, in afara de mesaj. N-ar trebui sa fie si un led de avertizare ?
  20. marcelush
    marcelush Banned
    22 Feb 2016
    Nu. Iti spune doar când pui contactul, ca trebuie sa completezi
