Audi Drive Select la A4 B8 - Instalare buton si/sau activare buton ADS
Discuție în 'Audi A4 B8 (2008 - 2015)' creată de george, 10 Iul 2012.
  1. nucugheri
    Salutare baieti, va rog sa ma lamuriti cu o problema : am facut adaptarea
    /codarea pentru ADS la un B8, am urmat toti pasii dupa modelul de mai jos. Mi-a aparut pe MMI, (doar cu contactul pus) am intrat in meniu dar am primit un mesaj ca pot sa setez un mod doar dupa pornirea motorului. Am pornit motorul, dar optiunea apare cu gri dupa pornire si nu pot alege nimic. Am gresit ceva? Si inca ceva, nu am inteles ultima codare, cea cu "ADS light adjustment", unde nu pot schimba bitul respectiv. E necesara si aceea? Mersi fain.
    AUDI DRIVE SELECT
    STEP 1
    Access Hidden Menu :
    Select "car" => Select "cardevicelist" => Check Charisma
    Press Return to go one menu back
    Select "carmenuoperation" => Change Charisma from 0 to 5
    Reset MMI
    STEP2
    [09 Cent. Elect.]
    [Coding 07]
    Longcoding Helper
    Byte 7, bit 5 - change 0 to 1. * (tells car ADS is installed, Charisma fault generated)
    Byte 8, bit 0 - change 0 to 1. *(changes gearbox to S mode)
    Byte 8, bit 1 - change 0 to 1. * * (enables dynamic steering)
    Byte 8, bit 2 - change 0 to 1. * (enables engine/gearbox) in menu
    Byte 8, bit 4 - change 0 to 1. * (enables steering in menu) possibly not required?
    Byte 17, bit 7- change 0 to 1. * *(enable MMI display)
    [Security Access 16]
    [Adaptation 10]
    Channel 63 change value from 2 to 4. * *( changes from auto factory default to individual)
    Channel 64 change value from 2 to 4
    Channel 65 change value from 2 to 4
    Channel 66 change value from 2 to 4
    Enter Security code on the VCDS software pop up into the relevant box
    ADS light adjustment ...Module 9, Byte 19 Bit 6.
  2. george
    george Gold Member
    21 Feb 2008
    Vad ca multi se confrunta acum cu acest meniu gri si nu inteleg de ce ...
    Light adjustmentul se face doar daca are si butonul instalat. Daca nu il are nu e necesara aceasta codare ;)
  3. nucugheri
    Multumesc George. O sa reiau operatiunea , sper cu succes de aceasta data.
  4. dr_dumi
    dr_dumi Bronze Member
    12 Mai 2008
    Audi A4 B9 190 CP Quattro
    nucugheri sa imi spui si mie daca iti iese ca si eu am problema asta cu optiunea greyed out si as vrea sa o activez si eu cumva..
  5. nucugheri
    Am reusit !!!:arco:
    dr_dumi, sa-ti spun care era "secretul" la mine : am reluat operatiunea de la inceput de 3 ori si tot la fel aparea cu gri, cu toate ca facusem totul ca la carte. Am inceput apoi sa verific fiecare bit modificat daca s-a pastrat codat, iar la Byte 17 bit 7 aparea 0, desi il facusem 1 si a fost acceptata codarea. Dupa inca cateva incercari nereusite de schimbare a acestuia din 0 in 1, mi-am notat valorile tuturor bitilor din Byte 17 dupa care i-am facut 0, apoi am schimbat prima data valoarea bitului 7 in 1, dupa care pe ceilalti i-am schimbat cum fusesera initial. (cred ca asta e un mic secret, am mai patit sa nu-mi ia codarea unui bit atunci cand si alti biti din Bytul respectiv sint codati deja, au valoarea 1). Do it, iar dupa asta mi-a aparut pe MMI ADS activ, dar numai Engine si Steering. Am facut niste teste, se simte diferenta intre comfort si dynamic, dar nu chiar asa cum zicea un coleg ca nu-si mai recunoaste masina pe modul dynamic :). Cam asta a fost, sper sa reusesti si tu. Succes.
  6. nucugheri
    Pentru colegii la care ADS-ul apare cu gri in MMI si nu e functional, dupa codare, am reusit astazi sa-l fac sa mearga, (dupa cateva incercari in urma carora aparea cu gri si la masina la care am efectuat aceasta codare) am explicat aici cum am reusit, poate mai e de ajutor pentru cineva.
  7. mircea-teodor
    mircea-teodor Silver Member
    17 Noi 2008
    Făgăraș
    Intrebare, cam offtopic:
    La ce masini din gama Audi s-a pus ADS ? Stiu ca la A5 din 2010 este , dar la celelalte ?
    Ultima editare de un moderator: 27 Apr 2013
  8. glumaretzuu Gold Member
    16 Mar 2008
    Bacău / Iași
    Audi A4 B8 2.0TDI
    ADS este disponibil de la lansare la A4 B8.
  9. mircea-teodor
    17 Noi 2008
    Făgăraș
    La A6 este? Modelul 2008-2011.
  10. Andrei_m
    Andrei_m 2nd Gear Member
    4 Mai 2009
    AUDI A4 B8/ 2011/ 2.0 TDI/ 120 CP
    Vad ca toata lumea vorbeste de instalarea ADS pe motoare de 143CP. Pe motor de 120 CP nu a incercat nimeni?
    O sugestie pt achizitia butonului puteti sa-mi dati? E vorba de varianta fara navi, in care acestaq ar trebui montat in consola de langa schimbatorul de viteze.
    Ștefan86 apreciază asta.
  11. dr_dumi
    12 Mai 2008
    Vezi la sectiunea publicitate, este un tip tucu.. care are un anunt cu f multe piese la vanzare, de la el poti lua butonul, stiu ca am intrebat si eu pt mine. Legat de motorul ala, nu stiu ce sa zic, astea de 120 cp nu sunt alea limitate pt noxe, gen pt tari ca Olanda/Belgia, or something?
  12. Andrei_m
    4 Mai 2009
    Multam de recomandare dr_dumi!
    S-ar putea sa ai dreptate in privinta limitarii, pt ca masina vine din Belgia...
    Si daca chiar e limitata (electronic, presupun), sa imi fac sperante cum ca as putea sa o duc la 143 CP relativ usor? Motorul e CAGC
    Ultima editare: 2 Mai 2013
  13. Sebastian2013 4th Gear Member
    8 Apr 2013
    Zalău
    Audi Q3 8U, 2.0 TDI
    Azi mi-am activat si eu meniul ascuns ptr un MMI 2g. Cum se activeaza ADS-ul din MMI? Difera meniul verde fata de ce am citit pe net.
    Topicul despre ADS l-ai citit ?
  15. chelule 3rd Gear Member
    6 Mar 2013
    Audi A4 B8 2010 2.0 143CP, Audi A3 Sportback 2009 1.6 16v 105CP
    Hidden Menu: (only for MMI cars)
    MMI Hidden Menu - Only for MMI equipped vehicles
    [car] [cardevicelist] ; check "carisma"
    [car] [carmenuoperation] ; change "carisma" from 0 to 5
    Reset MMI - Setup/Scroll Wheel/Top Right
    Coding:
    [09 - Cent Elect.]
    Byte 7 ; Bit 5 change 0 to 1
    Byte 8 Bit 0 Change 0 to 1 - Enable Engine/Gearbox (Improved throttle response and puts tranny into "S" mode when "D" is selected)
    Byte 8 Bit 1 Change 0 to 1 - Enable Dynamic Steering (Definitely stiffens steering on my car - a lot)
    Byte 8 Bit 2 Change 0 to 1 - Enable Engine (Improved throttle response - Not completely sure if I can feel a significant change)
    Byte 8 Bit 3 Change 0 to 1 - Enable Suspension (useless for cars w/o ads suspension)
    Byte 8 Bit 4 Change 0 to 1 - Enable Steering (not quite sure, doesn't really affect steering on my car)
    Byte 8 Bit 5 Change 0 to 1 - Enable Sports Differential (useless without sports diff installed)
    Byte 17 ; Bit 7 change 0 to 1 (enable MMI display)
    Byte 19 ; Bit 6 change 0 to 1 (enables correct lighting of ADS switch - only if ADS switch installed.
    Adaptations:
    [Security Access - 16] [Adaptation - 10] ; Channel 63 ; Change to [see below]
    [Security Access - 16] [Adaptation - 10] ; Channel 64 ; Change to [see below]
    [Security Access - 16] [Adaptation - 10] ; Channel 65 ; Change to [see below]
    [Security Access - 16] [Adaptation - 10] ; Channel 66 ; Change to [see below]
    (all four channels must have the same value!!)
    1 = Comfort
    2 = Auto (Factory default)
    3 = Dynamic - (Use this mode if you do not have MMI)
    4 = Individual (Activates MMI "Individual" menu - Use this mode if you have MMI)
    Byte/Bit guide:
  16. Sebastian2013 4th Gear Member
    8 Apr 2013
    Zalău
    Audi Q3 8U, 2.0 TDI
    Asa este hidden menu pentru MMI 3d, la 2d este diferit.
    Ex. in loc de car in MMI2d este vehicle...
  17. huskyuk 1st Gear Member
    28 Apr 2013
    Audi A4, 2.0TDI, Multitronic, 2010
    Interesant ar fii sa-l duci direct la 170 CP, daca tot pui problema de remapare. Cred ca vei avea o surpriza placuta ;)
    Am reusit si eu sa cuplez modul "dynamic" pentru motor. Nu am nici servotronic, nici amortizoare magnetice, nici MMI.. doar cutia multitronic.
    Intr-adevar se observa o schimbare in comportamentul masinii. Nici nu "turbeaza", nu e nici vax-albina.
    A disparut acea smucitura generata artificial de cutie pentru senzatia de "sport", acuma mi se pare ca trage constant, la fel ca pe "D".
    Turometrul sta mai mereu peste 2000, astfel, o pot calca fara probleme oricand, fara sa fortez turbina/DPF.
    Interesant este ca nu am observat o crestere a consumului fata de inainte.
  18. dr_dumi
    12 Mai 2008
    Pe cine pot si eu sa rog sa imi activeze si mie asta pana la urma, platesc daca e cazul, tre sa sa gaseasca cineva in stare sa activeze asta si pe masina mea (din moment ce a mai fost odata activata), cineva cu capu mare daca e :D
  19. valentinc 3rd Gear Member
    16 Ian 2011
    Audi A8 3.0tdi, 2007
    Vrei sa activezi butonul pentru ADS, sau sa activezi doar din module Charisma?
  20. dr_dumi
    12 Mai 2008
    Doar Charisma, fara buton, buton-ul il iau apoi daca e.. Sa vad ca merge mai intai. Nu vreau sa arunc 400 lei pe un buton ca apoi sa stea aruncat prin casa.
