Baterie - Electromotor - Alternator la A4 B8 - probleme diverse - cauze si rezolvari
Discuție în 'Audi A4 B8 (2008 - 2015)' creată de Valush, 17 Mar 2009.
  1. alex_ 4th Gear Member
    23 Feb 2010
    Audi A4 Avant 2009, 2.0 TDI (CAGA) 143cp
    Bateria mea originala este (inca) Varta AGM, 92Ah, 520A DIN, cod VAG 4F0 915 105 E, cod BEM VAO590217H02U.
    La o cautare pe Google nu gasesc Varta Silver Dinamic 92Ah.
    Pe site-ul Varta dupa ce introduc datele masinii, imi recomanda Varta Silver Dinamic 95Ah.
    Mai are cineva pe original tipul asta de baterie?
    Cand va trebui sa o inlocuiesc, in afara de varianta OEM ce optiuni pot avea? Varta de 95Ah, alti producatori cu 92Ah?
    Ultima editare: 30 Ian 2015
  2. Florin198787 2nd Gear Member
    24 Mai 2014
    Franta
    Audi a4 b8 2.0 TDI CAGA 2008
    Sall
    Poti sa mi zici si mie cum ai codat bateria pe masina dak sti toti pasi cum ai facut cu vag? Mersi
  3. andyzaharia
    andyzaharia Audi Expert
    11 Ian 2013
    Chișinău
    Florin198787 Vezi aici Ross-Tech - Battery Coding Assistant.
  4. Florin198787 2nd Gear Member
    24 Mai 2014
    Franta
    Care stiti daca audi A4 b8 2008 caga are unitate de management la baterie,puneti o poza care stiti cum arata aceasta unitate.mersi
    Iti dai seama si singur daca ai unitate de control / management a bateriei. Este o cutie atasata bateriei. Citeste acest topic. Bafta
  6. Florin198787 2nd Gear Member
    24 Mai 2014
    Franta
    03041 - energy management active. De la ce vine eroarea asta si cum o rezolv, care stiti ? Multumesc.
    Ultima editare de un moderator: 22 Apr 2015
  7. rotitza
    7 Oct 2008
    03041 - Energy Management Active
    Possible Symptoms
    Shut-Off Stage active
    Electric Systems disabled
    Infotainment System disabled
    Heating and/or Climate Control disabled
    Interior Lights disabled
    Window Regulators/Motors disabled
    Seat Memory/Adjustment disabled
    Auxiliary/Parking Heater disabled
    Possible Causes
    Battery discharged/faulty
    Quiescent Current
    Possible Solutions
    Check/Replace Battery
    Check for Quiescent Current Problems
    Perform (Quick) Quiescent Current Analysis
    Special Notes
    This Fault Code changes from static to intermittent once the Engine is started. It doesn't necessarily reflect a bad Component (the Control Module it's stored in) but rather points to an underlying Issue and merely documents a Symptom.
  8. Florin198787 2nd Gear Member
    24 Mai 2014
    Franta
    Am incercat sa intru sa codez bateria pe masina si nu i mi da voie sa intru pe baterie exista alta posibilitate cum pot sa o codez?
  9. celo
    celo Silver Member
    1 Iul 2013
    Audi A4 B8 2.0 TDI CAGA 2010 @ 180HP/400NM
    @Florin198787: Care sunt pasii pe care i-ai urmat si care a fost mai exact eroarea/problema pe care ai intampinat-o? Iti apare mesaj de "Low Battery" pe display in momentul de fata?
  10. Florin198787 2nd Gear Member
    24 Mai 2014
    Franta
    celo
    03041 - Energy Management Active - Possible Symptoms
    Problema e ca eu am scos bateria de pe masina sa o incarc si am inteles ca daca o demontezi trebuie recodata din nou pe masina. Are niste coduri pe ea.
    Ultima editare de un moderator: 24 Apr 2015
    Sergio apreciază asta.
  11. audi66
    Ai raspuns la o intrebare din 3.
    Ce pasi ai urmat ?
  12. Florin198787 2nd Gear Member
    24 Mai 2014
    Franta
    audi66 Am incercat sa intru pe 61 baterie si nu ma lasa, in bord nu imi apare low battery dar am indicator de baterie in MMI. Seara cand vin de la munca apare 100% incarcata si dimineata aproape de 25%, de abia porneste.
  13. audi66
    De ce ai scos-o sa o incarci ? Ai lasat masina mult timp nepornita sau aveai problema asta cu consumul bateriei mai demult ?
    Eroarea e recenta sau tu tot dai jos bateria si o pui la incarcat ?
  14. Florin198787 2nd Gear Member
    24 Mai 2014
    Franta
    audi66 Am uitat usa deschisa toata noaptea si sa descarcat,eroarea tot de atunci este,nu am mai avut probleme cu bateria pana acum
  15. audi66
    Intra pe 19 Can Gataway si vezi pe canalele 18, 19 si 20 ce valori ai. Fa o poza.
  16. Florin198787 2nd Gear Member
    24 Mai 2014
    Franta
    audi66 Intru maine si fac poze.
  17. rotitza
    7 Oct 2008
    Audi CAN Gateway Battery Coding (8T/8K/8R+)
    General Information: Most 2009+ Audi A4 and newer models do NOT use a separate 61-Battery Manager. In these cases battery management is a slave (subsystem) under the 19-CAN-Gateway control module. This page covers those 8T/8K/8R and newer models using a CAN Protocol 19-CAN-Gateway control module.
    If the vehicle in question uses a diagnostic capable 61-Battery Regulation controller this page should apply instead:
    Contents
    1 Long Adaptation
    2 Special Notes
    Long Adaptation
    Installation of a new battery requires the use of the [Long Adaptation-0A] function under 19-CAN-Gateway control module. Follow the onscreen instructions to enter the Part Number, Vendor, and Serial Number all as one long new value.
    Prerequisites:
    New Audi Battery Installed
    Aftermarket batteries may NOT have a valid Audi Part Number, Vendor code or Serial number. Ross-Tech cannot offer assistance if the necessary information is missing.
    Key On, Engine OFF
    [Select]
    [19 - CAN-Gateway]
    Channel 004
    [Read]
    VCDS will populate instructions in the form of a pop-up balloon with the formatting. For example:
    Format: NNNNNNNNNNN XXX ZZZZZZZZZZ
    N = Battery Part Number (11 Digits)
    X = Battery Vendor (3 Digits)
    Z = Battery Serial Number (10 Digits)
    [Add to Log] Saving the original value to a log is strongly recommended.
    Type the New Battery details into the New value field.
    Note, the New value must be 26 (alpha numeric) total characters including the spaces! If in doubt check the saved log for the original battery formatting details.
    [Test]
    [Save]
    Providing the value was accepted by the controller the new battery coding is complete.
    [Done, Go Back]
    [Close Controller, Go Back - 06]
    Note: The 10 digit serial number may be preceded by the Battery Vendor Code, for instance VA0. See examples below:
    Click on thumbnail image to enlarge.
    caption
    If the code is VA0310314E04G then drop the VA0 and just enter 310314E04G as the Serial Number.
    Special Notes
    Measuring Block groups 008, 019 and 020 should show Battery information.
  18. K U L
    K U L Platinum Member
    19 Ian 2009
    A6 4G 3.0 BITDI
    Florin198787 Daca ai lasat o usa deschisa nu are de ce sa iti consume bateria deoarece luminile din interior si de pe usa se sting in 10-15 minute. Daca ti s-a consumat din cauza asta, inseamna ca bateria e terminata si trebuie schimbata, degeaba o mai incarci.
    Apoi, ca sa incarci bateria nu e nevoie sa o scoti de pe masina, ridici capota si ai acolo langa rezervorul de lichid de frana un capac cu borna de + unde se da curent la masina, iar borna de - e pe oala amortizorului. Acolo poti pune un redresor sau sursa pentru incarcare.
    Informatia din can geteway referitoare la baterie nu se sterge nici daca scoti bateria, nici daca scoti gateway-ul efectiv si il lasi fara curent zile/saptamani. Deci nu ai de ce sa codezi din nou bateria, poti insa verifica daca informatiile de pe baterie sunt corect scrise in canalul indicat de rotitza mai sus. In cazul in care vei schimba bateria, atunci trebuie sa intri in canalul 004 si sa actualizezi informatiile.
  19. Florin198787 2nd Gear Member
    24 Mai 2014
    Franta
    K U L
    03041 - energy management active. Imi da si eroarea asta pe can gateway. Diseara scot plusul de la baterie sa vad daca pierde curent pana maine.
  20. K U L
    19 Ian 2009
    A6 4G 3.0 BITDI
    Acea eroare e normala pentru ca exista un sistem de management al bateriei, in momentul in care vede ca tensiunea a scazut sub o anumita valoare iti taie anumiti consumatori, lumini, muzica, etc. Daca bateria ta este obosita, imediat cum descui masina sau opresti motorul, tensiunea se duce sub 11.5V de exemplu si intra in actiune acest sistem sa impiedice consumul de catre sistemele auxiliare. Tot cu vcds poti verifica tensiunea bateriei, pe engine la measuring blocks parca....vezi tensiunea cu motorul oprit, tensiunea cu motorul pornit sa fii sigur ca incarca alternatorul si eventual tensiunea imediat dupa ce ai mers cu masina 20-30 min. Daca tensiunea cade brusc sub 12 cum ai oprit, trebuie alta baterie.
