BST - Audi A3 8P 2.0 TDI
Discuție în 'Masina mea / Prezentarea membrilor' creată de Bestie, 26 Apr 2008.
  1. orgonaskaroly
    orgonaskaroly Audi Expert
    14 Oct 2007
    Vad ca te-ai pus calumea pe treaba! O sa iasa o masinutza beton, spor la treaba in continuare:icon_thumright:
  2. Dr.Silviu
    Dr.Silviu Gold Member
    13 Mar 2008
    Audi A3 2007
    Am gasit ceva pe un site extern, referitor la codarea pentru oglinzile incalzite.
    The coding is in the door control modules (42 - driver door, 52 - pass door)
    It all depends on what your current coding is. I have the cold wx package and my coding is 1209 for both front doors.
    Here's the coding chart from VAGCOM label file for the driver's door:
    C00,Door Electronics Driver (J386) Coding
    C01,+0000001 - Rear Lid Remote Unlock Button (E233)
    C02,+0000002 - Ambient Mirror Illumination
    C03,+0000004 - Mirror Turn Signals
    C04,+0000008 - Interior Door Handle Illumination installed
    C05,+0000016 - Automatic Run active
    C06,+0000032 - Mirror Heater installed
    C07,+0000064 - Door Exit/Warning Light installed
    C08,+0000128 - 5-Door Chassis
    C09,+0000256 - Seat Memory installed
    C10,+0000512 - Right Hand Steering
    C11,+0001024 - Safe-Motor not installed
    C12,+0002048 - Pinch Protection inactive
    Here's the full label file from VAGCOM website:http://www.ross-tech.com/vag-c...N.lbl
    I'd assume that those without the cold wx pack might have a code of 1177
    If that is the case, you just add 32 for MIRROR HEATER INSTALLED
    Now if your current code is 1209, you're configured to use the mirror heaters, but still not sure if the wiring is all in place within the door to actually supply power to it.
    Page 98 of the owner's manual states "Turn the rotary knob to 0"
    "Depending on outside temperature and vehicle speed, the mirror surfaces are heated until the ignition is switched off"
    No need to push forward on the knob
    You can also turn on the heated mirrors by hitting the rear defroster button. Very handy for morning ice removal routine.
    A facut aceleasi modificari? Acolo spune ca trebuie sa apesi pe dezaburire spate sa-ti porneasca... Altfel, cand coboara sub 5grade!
    Si eu vreau sa fac aceasta modificare si nu stiu daca o sa mearga....
  3. Stefan
    Stefan Audi Expert
    9 Oct 2007
    pai nu poti decat sa incerci si apoi sa ne anunti si pe noi:p
  4. Dr.Silviu
    13 Mar 2008
    Audi A3 2007
    As incerca, dar el e cu un pas inaintea mea (a cumparat sticlele :p)
  5. Bestie
    Bestie 5th Gear Member
    7 Apr 2008
    Audi A4 B6 1.9 TDI Quattro AVF 2003
    O sa "pasez" mai departe textul de la tine si sa-mi spuna persoana care ma ajuta pe mine in cazuri d-astea ce parere are. Multumesc pt idee :D:D:D
  6. Stefan
    Stefan Audi Expert
    9 Oct 2007
    asteptam cu nerabdare:icon_thumright:
  7. Bestie
    7 Apr 2008
    pozele promise ieri
  8. Stefan
    Stefan Audi Expert
    9 Oct 2007
    n'am prea fost pe faza. ai gasit doar capac la cotiera?cat te'a ajuns?ca si la mine e rupt:p
  9. Bestie
    7 Apr 2008
    da. am luat printre altele si un capac nou de cotiera. 1.600.000 a costat la Midocar.
  10. orgonaskaroly
    14 Oct 2007
    Mi se pare scump 50 de euro, dar asta e, spui Audi, te-au ars imediat, eu sunt multumit de magnetii mei:)
  11. Bestie
    7 Apr 2008
    O parte din probl. care le aveam le-am rezolvat, mai sunt cateva, dar e oarecum normal pentru ca masina nu a fost noua. Am schimbat stegatoarele fata/spate, capacul de cotiera, suportul de pahare, burduful de planetara, am rezolvat probl. cu sina suportului de pahare de sub cotiera, zgomotul de la pornire am inteles ca e din cauza uleiului din cutie care e vascos si tre' sa se incalzeasca un pic, ţăcănitul acela la viraj stanga/dreapta pe loc e prezent la mai multe A3-uri din generatia mea (si nu-mi mai fac probleme din cauza asta), sub-woofer-ul din fabrica ca l-am rezolvat, mai exact am montat muzica after-marker si nu mai ma "doare" care era problema lui, din cate am inteles putea fi activat din Vag-Com.
    Mai sunt de rezolvat una-alta, cum ar fi ca usile trebuie reglate un pic, pentru ca daca le incerci sa le inchizi foarte incet acestea nu se inchid cum trebuie, dar inca nu stiu la cine sa apelez pentru un astfel de reglaj. Stergatorul din dreapta sta un pic prea sus si probabil ca trebuie desfacut si montat un pic mai jos pe ax, sa fac lumina de la suportul de pahare.. si am un zgomot la articulatii cu care eu nu sunt prea impacat, unii mi-au spus cum ca ar fi bucsele de bara stabilizatoare, dar nu mi le-au comandat ca vin cu tot cu bara, cand am vrut sa iau eu bara cu totul, cei de la alt service mi-au ridicat masina pe elevator si mi le-au aratat cum joaca.. adica foarte putin spre deloc.. deci n-ar fi de la ele... Un prieten mi-a spus ca e din cauza faptului ca masina are suspensie sport de fabrica... Cu astea inca nu m-am lamurit...
    Aaaa, si latest news, mi-a scazut nivelul la lichidul de racire.. dar nu stiu de ce. Se stie de vreo problema "clasica" la A3 legata de lichidul de racire?
  12. kellu
    kellu Platinum Member
    19 Aug 2007
    Mioveni
    Opel Corsa
    poate ca ai mers cu aerul pornit. Si mie mi se intampla la fel: cand nu foloseam clima nu scadea, cand foloseam clima trebuia sa completez nivelul de antigel si nu stiu din ce cauza o fi :think:
  13. Cata_ADC
    14 Feb 2008
    Brasov - Zarnesti
    alta marca I3 , e-drive 2018
    Sincer nu stiu pe cineva sa aibe probleme cu antigelul la A3.
  14. Bestie
    7 Apr 2008
    Mi-am cumparat si lichid de racire si ulei pentru ca am inteles ca acest motor face parte din categoria celor care "mananca" ulei. Legat de cel de racire, desi e sub minim in vas nu am completat pentru ca "check"-ul din bord nu-mi spune ca ar fi ceva in neregula... Voi ce ziceti sa completez sau sa astept sa imi apara in bord faptul ca trebuie adaugat? In cazul in care trebuie sa completez eu e ok sa desfac vasul si sa torn acolo "dupa ochi"? E vreo problema daca deschid vasul ? Ca ma gandesc ca poate nu e ok sa intre aer... Voi ce spuneti?
    In alta ordine de idei am reusit sa rezolv iluminarea suportului de pahare, dupa ceva chinuri. Pe langa asta, mai am o "realizare". De acum incolo nu-mi mai bat capul cu incalzirea oglizilor pentru ca am incercat azi sa le scot din carcasa pentru a le scoate un fir sa vedem daca da vreo eroare pe Vag-Com, dupa ce am executat modificarile care mi le-a spus colegul Dr.Silviu la postul nr. 42, si le-am spart... Pe amandoua. Asa ca am revenit la cele vechi. Oricum... e ceva dubios acolo. Daca nu mergea incalzirea sub nici o forma, ce mai cautau acolo firele???
  15. orgonaskaroly
    14 Oct 2007
    Nu te-ai lasat, pana nu le-ai facut tandari:) Referitor la vasul de espansiune, sa-l deschizi, doar cand motorul este rece!!!!! Nu are nimic daca il deschizi, numai sa fie rece motorul, completeaza linistit dupa ochi ca nu trebuie sa fie la milimetru nivelul. Eu zic sa completezi doar cu apa distilata, pentru ca doar apa se evapora nu si antigelu!!! In cazul in care ai pierderi pe undeva, atunci trebuie sa completezi amestecat si apa si antigel, dar daca nivelul scade doar pentru ca se evapora apa atuncea numai cu apa distilata trebuie completat! Nu astepta sa-ti apara pe bord, vezi care e nivelu la rece si atuncea sa completezi. Bafta
  16. Bestie
    7 Apr 2008
    Eu am cumparat lichid de racire G12 nu apa distilata. E ok sa completez cu acesta? Sincer, nu stiu motivul pentru care-mi pierde... daca e vorba de evaporarea apei sau de altceva... Nici nu stiu ce a avut masina pana acum in ea, G 12 sau G 12 in amestec cu apa... tot ce stiu e ca lichidul este rozaliu...si este sub pragul de minim!!! Pana la urma cum sa fac?
  17. kellu
    19 Aug 2007
    Mioveni
    Opel Corsa
    are semne de min si max pe vas
  18. Dr.Silviu
    13 Mar 2008
    Audi A3 2007
    Poti sa pui G12 pana la max (ai grija ca motorul sa fie rece!) Eu am avut aproape de minim si la revizie mi-au completat pana la max....
    P.S: imi pare rau pentru oglinzi :( Nu stiu cum ai reusit sa le spargi... Eu le-am dat jos de nu stiu cate ori si nu mi s-au spart...
    Poate pana la urma rezolvi si cu astea...
    Ultima editare: 23 Mai 2008
  19. orgonaskaroly
    14 Oct 2007
    Exact. Oricum asta nu e o problema, chiar daca bagi doar antigel. Eventual sa te duci la cineva care are densimetru ca sa-ti masoare concentratia antigelului, ca pe viitor sa stii daca sa completezi doar cu apa distilata sau sa bagi si antigel.
  20. Cata_ADC
    14 Feb 2008
    Brasov - Zarnesti
    Stie karoly ce spune.:)
    E important sa ii masori concentratia mai ales iarna :)
    Eu sincer iti spun ca nu am nici o problema nici cu antigelul nici cu uleiul.
    Si are km si merge si nonstop masinuta. Si inca cum :)
