Salutare, Am cautat pe net codarei pentru Audi Q7 4M si am gasit mai multe. *Sursa: http://www.vwaudiforum.co.uk/forum/showthread.php/176518-Q7-(4M)-Coding In priul rand codurile de securitate pentru cateva module: 09 - Central Electrics: 20113 13 - Auto Distance Regulation: 20103 6D - Trunk Electric: 12345 57 - TV Tuner: 20103 CA - Sunroof: 20103 MMI Reboot Sometimes the changes require the MMI to be rebooted (like a 3 finger salute on a computer) for changes to show up/take effect. Switching the ignition off/on isnt enough In the Q7 (4M) a 3 Finger salute is done by holding the Nav and Radio Buttons "up" and then pressing the main rotary knob. This will cause the MMI to do a quick reboot. Needle Sweep Description: When the ignition is turned on the Needles in the Virtual Cockpit or Non-Virtual Cockpit will do a full cycle of the RPM and Speed Dials Risk: Low Usage: Start Car Software: VCDS (others will work) Coding: Module 17 (Instruments) Coding Long Coding Long Coding Helper Byte 1 (Second from left) Tick/Select "Bit 0" Exit Do It ----------------------------------------------------------------------- Lap Timer Description: Enable the ability to record lap times as soon as the car starts moving or manually started. Includes Split Time function, Lap Reset. If you have a HUD (Head Up Display) The Gear Selection (e.g D6/S6), Oil Temp and Lap timer counter will be displayed in the HUD. Note, the Lap timer "counter" in the HUD doesnt run for some reason but does on the Virtual Cockpit Notes: Not tested on the Non-VC Dashboard, but should work Usage: Nothing on main MMI screen, all driven from Instrument Cluster screen. Ensure you are on the "Red" Car screen (not radio/nav/phone) and you should see a new Left "Context" Menu option. Use arrow buttons on the left of steering wheel to navigate. Risk: Low Software: VCDS (others will work including ODBEleven - Thanks Wolek76) Coding: Module 17 (Instruments) Coding Long Coding Long Coding Helper Byte 1 (Second from left) Tick/Select "Bit 3" Exit Do It ----------------------------------------------------------------------- Seat Belt Chime Disable Description: By default, if the driver or any other passenger does not have their seat belt engaged a "Chime" will repeatedly make a noise until the seat belt is engaged if you start driving. There appears to be two methods to disable this Seat Belt chime. Method 1: Using Long Coding Method 2: Changing an Adaptation Channel Notes: The chime is disabled for the driver and any passenger in the front or middle row. The 5 seat icon on the instrument cluster will still show when seats are occupied when using the Adaptation Channel method as far as we can tell. Usage: None Risk: Low Software: VCDS Method 1: Module 17 (Instruments) Coding Long Coding Long Coding Helper Byte 0 (First from left) UnTick/DeSelect "Bit 2" Exit Do It Method 2: Module 17 (Instruments) Adaptation Scroll down to "Deactivate seat belt warning" Stored Value should be "No" (Default) Change to "Yes" Do It ----------------------------------------------------------------------- Tailgate Opening Delay - Via Remote Key Fob Description: When you stand near the rear of the car and press & hold the middle boot "release" button on the key fob, the boot will open and rise after a 0.8 second (800ms) delay. This coding can change the delay to a longer value (e.g. 2.0 seconds (2000ms)) Notes: Only tested on a Q7 4M with Advanced Key option but should work on any. Value only tested is 2000ms. Not sure what maximum value can be or if value can be lower than 800ms Usage: Use with middle boot/trunk release key on key fob Risk: Low Software: VCDS Coding: Module 46 (Central Convenience) Adaptation Scroll down and find channel "Time for opening rear lid with remote control" Load Stored Value (should be 800 ms) Enter new value in "ms". Example: 2000 Do It Test the delay ----------------------------------------------------------------------- Adaptive Cruise Control Distance Regulation Set Description: For Q7 (4M) cars that are fitted with ACC (Adaptive Cruise Control) you can set the default "Distance" the ACC sets to when you enable ACC. The Default value is "3 Lines". Notes: Will only work in cars with Adaptive Cruise Control fitted. Do not attempt if you dont have ACC. If you have HUD (Head Up Display) it will flash up the distance level you have set when you switch the ignition on. Usage: Once MMI rebooted (see above), go into Car/Driver Assist/Audi Adaptive Cruise Control. You should see a new menu called "Basic Setting" (It might be called "Standard Setting" if your in the USA). Choose this to set the Distance Level from 1 to 5 (each one representing a "line"). Finally. once set, push the ACC stalk all the way out (towards front of car) so its fully off. Click it back in. This switches ACC "off" and "on" and is needed to pick up the new setting. Risk: Medium Software: VCDS / VCP (Others may work) Coding: Module 13 (Auto Dist. Regulation) Security Access Enter Code "20103" Do It It should say "Security Code Accepted" Go into Adaptation (Still in Module 13) Scroll through channel list to "Distance basic setting option" Stored Value should be "Off" (Default) Set New Value to "On" Do It Exit Reboot MMI using Reboot method in top post of this thread. ----------------------------------------------------------------------- Lock/Unlock "Chirp" Description: For Q7 (4M) cars in the USA, when you lock the car, you will hear a single or double "chirp" (from a second sounder, not the horn). This is a good audible confirmation that the car is locked. This coding enables lock chirp on Non-USA cars but also enables an "unlock" chirp if/when the car is unlocked. Notes: There are many options to configure including how long the chirps are, whether you want single or double chirps for lock/unlock as well as updating the indicator flashes to match the number of chirps. There is both Long Coding & Adaption Changes for this modification. Usage: Once coded it will work immediately on lock/unlock. In addition, if you lock the car (if you have Advanced Key) using the padlock button on the trunk, the chirp will sound when the trunk is fully engaged. You can also turn off the "Chirp" via the MMI under Car / Vehicle Settings / Central Locking Risk: Medium / High (Depending on number of options you change). Please note there are a lot of combinations below so please GO SLOWLY. Coding: Module 46 (Central Convenience) Coding Long coding Long coding helper (VCDS) Byte 4 Select/Tick "Bit 6" Exit Do It This will enable the "Tone when Locking" option in the MMI under Car / Vehicle Settings / Central Locking ----------------------------------------------------------------------- LOCKING CAR ADAPTION: Adaption Changes for "Chirps" when LOCKING the car: Module 46 (Central Convenience) Adaption Find channel "(2)-sounder_settings-beeptime_closing_central_locking" Default Value is "single_beep" If you want a single "chirp" when you lock the car, leave this setting as is. If you want a double "chirp" when you lock the car, change the value to "double_beep" Do It ----------------------------------------------------------------------- Adaption Changes for number of "Indicator Flashes" when LOCKING the car: Module 46 (Central Convenience) Adaption Find channel "(3)-Turn Signal control-Confirmation flashing locking central locking; flashing cycles" Default Value is "1" If you want a single indicator "flash" when you lock the car, leave this setting as is. If you want a double indiactor "flash" when you lock the car, change the value to "2" Do It ----------------------------------------------------------------------- UN-LOCKING CAR ADAPTION: Enable "Beep on Unlock" Module 46 (Central Convenience) Adaption Find channel "(1)-central_locking_system-beep_at_opening" Default Value is "Off" Change Value to "On" Do It ----------------------------------------------------------------------- Adaption Changes for "Chirps" when UN-LOCKING the car: Module 46 (Central Convenience) Adaption Find channel "(4)-sounder_settings-beeptime_opening_central_locking" Default Value is "no_beep" If you do NOT want a "chirp" of any sort when you UN-lock the car, leave this setting as is. If you want a single "chirp" when you UN-lock the car, change the value to "single_beep" If you want a double "chirp" when you UN-lock the car, change the value to "double_beep" Do It ----------------------------------------------------------------------- Adaption Changes for number of "Indicator Flashes" when UN-LOCKING the car: Module 46 (Central Convenience) Adaption Find channel "(3)-Turn Signal control-Confirmation flashing unlocking central locking; flashing cycles" Default Value is "2" If you want a double indicator "flash" when you UN-lock the car, leave this setting as is. If you want a single indicator "flash" when you UN-lock the car, change the value to "1" If you want a NO indicator "flash" when you UN-lock the car, change the value to "0" Do It ----------------------------------------------------------------------- DRL (Daytime Running Lights) On/Off Option in MMI Description: For Q7 (4M) cars you are unable to turn the DRLs on or off in the MMI. This coding enables this option in the MMI. Notes: Tested with Matrix headlights but same coding applies to non-Matrix headlights. Usage: Once configured, go into MMI and go to Car / Vehicle Settings / Exterior Lighting. A new option will appear to turn the DRL's on or off. Risk: Low Coding: Module 09 - Central Electics Coding Long coding Long coding helper (VCDS) Byte 2 Select/Tick "Bit 1" Exit Do It ----------------------------------------------------------------------- Enable ability to Rip CD's to MMI "Jukebox" Description: For Q7 (4M) cars, you can put a CD into the CD player in the glovebox (or multichanger in boot) and "rip" the contents to the internal Jukebox storage within the MMI system. Notes: Requires Coding and Adaption Changes. You also need to "reboot" the MMI after the changes (see reboot procedure at top of this thread). Album artwork is sync'd if you have "Gracenote online database" selected. Usage: Go to "DVD" under Media and bring up right context menu. Will see new option "Rip to Jukebox". Select and choose whether to rip single track or whole CD Risk: Low Coding: Module 5F - Information Electr Coding Long coding Long coding helper (VCDS) Byte 24 Select/Tick "Bit 5" Exit Do It Adaption: Module 5F - Information Electr Adaptation Scroll down and find channel "(2)-Copy multimedia data-Optical drive" Load Stored Value (should be set to "Off") Change to "On" Do It Exit
Audi Active Lane Assist - Steering Vibration Adjustment Description: For Q7 (4M) cars that have the Audi Active Lane Assist fitted (can be part of "Dynamic Pack") you can adjust the 'vibration' level between weak/medium/strong. The default is "Medium" Notes: Only applies if you have Audi Active Lane Assist fitted. You can tell if you have the 2 'lines' that represent road markings in the VC or non-VC and/or Head Up Display. Its enabled/disabled with the button on the end of the left hand stalk. Usage: Wait until Lane Asssist has detected road markings (Green lines) and drive slightly over a road line so the lane marking changes to Red. The vibration of the steering wheel should be adjusted according to the level you have set. Risk: Low Adaption: Module A5 - Front Sens. Driver Assist Adaptation Scroll down and find channel "IDE05985-Directional stab. assist ; intensity; steering wheel vibration" Load Stored Value (should be set to "Medium") Change to either "Weak / Medium / Strong" Do It Exit ----------------------------------------------------------------------- Lock When Driving Description: For Q7 (4M) cars when you drive off the doors automatically lock when a certain speed is reached. This change allows you to control whether you want this on or off. It is enabled by default. Notes: None. Usage: Once configured, go into MMI and go to Car / Vehicle Settings / Central Locking. A new option will appear to toggle "Lock When Driving" on or off. Risk: Low. Coding: Module 46 - Central Convenience Coding Long coding Long coding helper (VCDS) Byte 35 DE-Select/UN-Tick "Bit 0" (It should be TICKED by default. You need to UNTICK/UNSELECT it) Exit Do It ODBEleven Coding: Module 46 Control Module "Comfort System" Coding Find "auto_lock_not_at_mmi" Value is set to "Active" Change Value to "Not Active" Apply ----------------------------------------------------------------------- Disable "Low Wind Noise" Stop point on Sunroof Description: For Q7 (4M) cars with the electric Panoramic Sunroof fitted only. When you slide back the sunroof "slide" option the sunroof will stop about 4/5 of the way back. This is the "Low Wind Noise" position. You then slide the switch once more briefly to open the sunroof fully. This change disables the "Low Wind Noise" position and opens the sunroof fully with just one flick of the switch. Notes: None. Usage: Once configured, flicking the sunroof switch back fully once will result in the sunroof sliding back the whole length without stopping at the "Low Wind Noise" position. Risk: Low. Coding: Module CA - Sunroof Security Access Enter Code "20103" (you may be able to make this change without needing the security code) Adaption Find channel "IDE09451-MAS08937-Travel path-Sliding Position: intermed. pos." Value should be "Active" Change to "Not Active" Do It ----------------------------------------------------------------------- Parking Assist Camera - Turn Off Speed Description: For Q7 (4M) cars that have either the Rear Camera fitted, Park Pack Assist or Park Pack Advanced you can alter the speed at which the cameras will automatically turn off. By default it is 6 mph. Notes: Only applies if you have a rear camera or above fitted. Usage: None. Will turn off the camera screen on the MMI at a higher speed than default. You can also press the Parking camera button on the dash while slowing down to a junction for viewing if required Risk: Low Adaption: Module 09 - Central Electrics Adaptation Scroll down and find channel "Switch off speed for park assist" Load Stored Value (should be set to "10 Kph / 6 Mph") Change to another value. Example "20" (which is about 12 Mph) Do It Exit ----------------------------------------------------------------------- Seat Symmetry + Passenger Seat Control Description: For Q7 (4M) cars that have BOTH Driver and Passenger memory seats installed (with the buttons in the doors) you can make both the drivers seat and passenger seat "line up" so they are symmetrical. In addition, you can move the passenger seat using the seat movement buttons on the drivers seat. This change enables these features if you have ONLY Driver Memory Seat installed Notes: Not been tested on Q7 4M cars that have neither driver or driver/passenger memory seats installed but it should work. You need to do the SAME coding in Modules 06 and 36. Usage: Once coded, go into MMI, Car / Vehicle Settings / Seats. A new option for Passenger Seat will have appeared. There will be 2 options inside. One to line both front seats up together, and the other to move the passenger seat with the driver seat movement buttons Risk: Low Coding: Module 06 - Passenger Seat Module & Module 36 - Driver Seat Module Coding Long coding Long coding helper (VCDS) Byte 2 Tick "Bit 5" Byte 6 Tick "Bit 1" Exit Do It ----------------------------------------------------------------------- Enable & Pair a Second Phone via Bluetooth simultaneously Description: For Q7 (4M) cars that have the "Audi Phone Box" installed (Wireless Charging Cradle etc.) you get the ability to have 2 phones simultaneously connected to the car via Bluetooth. If you do not have the Audi Phone Box you can only have 1 phone connected via Bluetooth at any one time. This change enables the ability to connect 2 phones simultaneously via Bluetooth without the Audi Phone Box being installed. Notes: Reboot MMI after configuring Adaptation channel. Usage: Once configured and MMI rebooted go into "Connection Manager" in the MMI and you will see a new line to pair a second phone. See photo below. Risk: Low. Coding: Module 5F - Information Electronics Adaptation Scroll down till you find channel "IDE03471-ENG130247-Vehicle configuration-Support_second_phone" (name may be slightly shorter in ODBEleven) Load Stored Value (Default will be "Not Active") Change to "Active" Do It Exit Reboot MMI using 3 finger salute at top of this thread. ----------------------------------------------------------------------- Enable Ability to lock car with Engine running Description: By Default Q7 (4M) cars can't be locked via the lock button on the keyfob or the button on the door (if you have convenience key) if the engine is running. This change enables the car to be locked while the engine is running. This is useful to say, for example warm the car up but keep it locked on your driveway. Notes: If you having folding mirrors, they do not retract once you lock the car. Usage: Once configured start car engine, get out car and lock. Engine will remain running. Risk: Low. Coding: Module 46 - Central Convenience Coding Long Coding Long Coding Helper Byte 9 Tick Bit 7 Exit Do It ODBEleven Coding: Module 46 Control Module "Comfort System" Coding Find "central_locking_system_lock_unlock_at_engine_runni ng" Value is set to "Not Active" Change Value to "Active" Apply
"Energy Consumers" in Cockpit Enable Description: It was found that the "Energy Consumers" option in the 'Car' section on the Virtual Cockpit was not displaying on all Q7 4M's from factory. This coding change enables that option. Notes: This has not been tested on a Q7 4M without Virtual Cockpit, but its highly likely it will work. Usage: Once configured you will find a new "Energy Consumers" section on the information panel on the Cockpit (as shown by picture link below) Risk: Low. Coding: Module 17 Coding Long Coding Long Coding Helper Byte 1 Tick Bit 7 ("Body Computer with efficiency program,Yes") Exit Do It Picture of "Energy Consumers" information panel on a Virtual Cockpit *Thanks to nbedford for confirming this change works. ----------------------------------------------------------------------- Enable Easy Entry for Drivers Seat Description: By Default Q7 (4M) cars that have the electric steering column option, the drivers seat will move back automatically when the car is turned off and the drivers door is opened to allow easy exit of the vehicle. In addition, when unlocking the car and opening the drivers door the drivers seat will move back to allow easy entry and upon starting the car the seat will move forward back to the last position. If you have Convenience/Advanced Key and Driver Memory seats then when you start the car the seat will move to whatever memory recall is stored on the key used to unlock the car (linked with button 1 or 2 of the driver memory seat buttons in the door trim). This change enables this feature when the electric steering column is not installed. Notes: This has not been tested on a Q7 4M without driver memory seat buttons, but it should work. Also, you may find the Easy Entry option "greyed out" in the mmi. If so, lock the car, wait 30 seconds then unlock and try the menu option again. Usage: Once configured get out at lock the car and wait 30 seconds, go back into car and start electrics, you should see Easy Entry option under "Vehicle Settings / Seats / Drivers Seat". Make sure its ticked. Risk: Low. Coding: Module 09 Central Electrics Coding Long Coding Long Coding Helper Byte 14 Tick Bit 2 (easy_entry_steering_column_via_mmi_configurable,a ctive) Exit Do It Coding: Module 36 Seat Memory Driver Coding Long Coding Long Coding Helper Byte 3 Tick Bit 6 (Easy_Entry_front,0=not active / 1=active) Exit Do It If you want Easy Entry enabled on the Passenger seat then repeat as below but for Module 06 (Seat Memory Passenger) instead of Module 36 Coding: Module 06 Seat Memory Passenger Coding Long Coding Long Coding Helper Byte 3 Tick Bit 6 (Easy_Entry_front,0=not active / 1=active) Exit Do It Reboot the MMI ! ----------------------------------------------------------------------- Disable Child Lock on Rear Heating Controls when Child Lock buttons enabled in Drivers door Description: For Q7 (4M) cars that have the "Deluxe" rear heating controls (in the middle between the front seats with the LCD display etc), if you have the Child Lock buttons switched on via the driver's door buttons to stop the rear doors from being opened from the inside, this also disables the rear heating controls from being used. Instead when you attempt to use them a "Padlock" symbol is displayed. This change disables that so the rear doors can still be child lock "protected" but the rear heating controls will work. Notes: Only tested on the "Deluxe" rear heating controls with the LCD screen and the red/blue heater controls. Usage: Enable the Child Lock buttons on the drivers door trim by the window up/down controls and the rear doors will be child lock protected from opening from the inside, however the rear heating controls will still be changeable. Risk: Low Adaption: Module 28 - HVAC Rear Coding Long Coding Helper Byte 11 Untick Bit 7 (child_proof_lock,0=not installed / 1=installed) Tick "Soft Reset" (in the Long Coding Helper in VCDS) Do it
Am reusit cu interfata VCDS 14 sa dezactvez centurile, sa combin camerele 360 cu senzorii de parcare, sa modific viteza la care se dezactiveara asistenta la parcare de la 10km/h la 20km/h. In 2 zile imi ajunge interfata 18. Voi incerca posibilitatea de a incuia masina cu motorul pornit. Codari de genul easy entry(ridicarea volanului si miscarea scaunului soferului in spate) le are masina din fabrica.
