Am si eu o intrebare referitor la erorile de la cutie. Cred ca este calculatorul si as vrea sa il repar masina merge bine nu smunceste Dar as vrea sa fiu sigur ca calculatorul cutiei este vinovat de aceia va cer sfatul si parerea Audi a4 b7 2006 motor BRE cutie 7+1 multitronic cod GYJ Anul trecut aparea cate o data doar eroare senzor F125 si isi revenea anul acesta a aparut si eroarea senzor g196 care disparea cate o data acum e permanenta. Address 02: Auto Trans Labels: 01J-927-156.lbl Part No SW: 8E0 910 157 H HW: 01J 927 156 HT Component: V30 01J 2.0l PD RdW 0040 Revision: 00000008 Serial number: 00000000945968 Coding: 0000001 Shop #: WSC 06325 000 00000 VCID: 2C57E23B8FFEEC7E18B-8079 2 Faults Found: 17090 - Transmission Range Sensor (F125) P0706 - 000 - Implausible Signal Freeze Frame: Fault Status: 01100000 Fault Priority: 0 Fault Frequency: 254 Reset counter: 255 Time Indication: 0 Date: 2064.00.00 Time: 00:00:00 Freeze Frame: RPM: 96 /min RPM: 0 /min (no units): 1.0 Torque: -24.0 Nm Temperature: 71.0°C T.B. Angle: 0.0° Bin. Bits: 0001 0 0 18201 - Transmission Output Speed Sensor 2 (G196) P1793 - 000 - No Signal Freeze Frame: Fault Status: 01100000 Fault Priority: 0 Fault Frequency: 254 Reset counter: 255 Time Indication: 0 Date: 2064.00.00 Time: 00:00:00 Freeze Frame: RPM: 864 /min RPM: 60 /min (no units): 2.0 Torque: 8.0 Nm Temperature: 73.0°C T.B. Angle: 0.0° Bin. Bits: 1010 0 0 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8E0-910-517.clb Part No SW: 8E0 910 517 D HW: 8E0 614 517 AK Component: ESP8 front H06 0120 Revision: 00000000 Serial number: 00000000000000 Coding: 0004402 Shop #: WSC 06325 000 00000 VCID: 285F1E2B9B06C05EFC3-807D 1 Fault Found: 01119 - Gear Recognition Signal 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 3 Fault Frequency: 29 Reset counter: 40 Time Indication: 0 Freeze Frame: Hex Value: 0x0000 Hex Value: 0x4226 Hex Value: 0x0031 Hex Value: 0x01AF Hex Value: 0x0000
Salutare! Detin un Audi A4 B7 din 2007 cod motor BPW cutie automata 7+1. Masina schimba foarte bine treptele doar ca uneori PRNDS stau toate aprinse iar in modul manual trece dupa cateva incercari. Am atasat erorile din VCDS si v-as ruga daca imi puteti da un sfat sau o parere. Multumesc!
Si cei / cel care au/a facut diagnoza de ce nu ti-a spus cum remediezi ? De ce faci diagnoza la cineva care nu se pricepe ? In diagnoza iti spune clar ce ai de facut. Iar despre aceste erori s-a discutat de mai multe ori pe forum.
Trebuie sa faca exact ce a facut colegul, 2 posturi mai sus chiar daca difera erorile pentru ca sunt legate de acelasi lucru adica calculatorul TCM. Afla asta daca citea tot topicul in loc sa astepte raspunsuri.
Buna ziua, Dupa 14 ani de utilizare, multitronic ul ( reconditionat in 2009 ) de pe masina mea, se pare ca a obosit sa functioneze. Incarc niste poze. VCDS scan fac in 2 ore . Revin video mai jos
@italexei faci diagnoza degeaba. Nu exista sa stea pe forum reparatori de cutii automate la dispozitia noastra. Mergi si repari / reconditionezi din nou cutia sau cauti alta cutie, cu acelasi cod, ca a ta. Sau, mai exista posibilitatea unei defectiuni (si eu cred ca de acolo ai tu probleme) la calculatorul = TCM-ul cutiei de viteze automate si daca este asa exista reparatori buni pentru asta in Romania. Cred ca la Campina gasesti pe cineva care repara TCM-ul cutiei automate. Exista aici pe forum date de contact pentru acel domn reparator si discutii despre cum rezolvi problema TCM-ului. Asta este tot ce ai de facut. Bafta.
