  1. mr_x4you 4th Gear Member
    13 Iun 2011
    A6 2.5 TDI 2002
    Este trecut 506.00 pentru motorul ala. Asta e pentru long life cu schimbare la 2 ani sau 30000km. In manualul de service se recomanda pentru intervalul normal de schimb (15000km sau un an) ulei cu norma 505.00. Desigur ca poti pune 506.00 (inlocuit acum de 507.00) si sa schimbi la un an sau 15000km dar atunci arunci cu banii. Si ce e cel mai important, nu mai pune ulei semisintetic in motor, chiar daca are kilometrii aia.
  2. Silviu.r
    Silviu.r 1st Gear Member
    9 Oct 2010
    A6, 2.5 TDI 2002
    ok, multumesc frumos
  3. ro24tnt 1st Gear Member
    8 Apr 2010
    A3, 1.9 TDI, 2001
    salut,
    am cumparat recent un A3 din 2001 1.9 TDI cu QG1 Service interval prolongation. acum cred ca are 5W40. ce ma sfatuiti: sa pun in continuare 5w40, sau 0W30 sau noul 5w30? indiferent de alegere planuiesc sa le schimb pana in 15000 km
    este motor PD fara filtru particule
    multumesc
  4. mr_x4you 4th Gear Member
    13 Iun 2011
    A6 2.5 TDI 2002
    5W40 daca schimbi la maxim 15000km.
  5. lxl
    lxl Gold Member
    27 Ian 2009
    Poate va ajuta sa intelegeti cat de importante sant acele cifre de pe ambalaj.
    A quick guide to the different grades of oil.
    Fully Synthetic Characteristics
    0W-30
    0W-40
    5W-40 Fuel economy savings
    Enhances engine performance and power
    Ensures engine is protected from wear and deposit build-up
    Ensures good cold starting and quick circulation in freezing temperatures
    Gets to moving parts of the engine quickly
    Semi-synthetic Characteristics
    5W-30
    10W-40
    15W-40 Better protection
    Good protection within the first 10 minutes after starting out
    Roughly three times better at reducing engine wear
    Increased oil change intervals - don't need to change it quite so often
    Mineral Characteristics
    10W-40
    15W-40 Basic protection for a variety of engines
    Oil needs to be changed more often
    The full ACEA specs are:
    * A1 Fuel Economy Petrol †
    * A2 Standard performance level
    * A3 High performance and / or extended drain
    * A5 Fuel economy petrol with extended drain capability †
    * B1 Fuel Economy diesel †
    * B2 Standard performance level (now obsolete)
    * B3 High performance and / or extended drain
    * B4 For direct injection passenger car diesel engines
    * B5 Fuel economy diesel with extended drain capability †
    † Not suitable for all engines - should ONLY be used in engines specifying this fuel efficient grade. Refer to the manufacturer handbook of contact your local dealer if you're not sure.
    Mineral oils:
    * E1 Non-turbo charged light duty diesel
    * E2 Standard performance level
    * E3 High performance extended drain
    * E5 (1999) High performance / long drain plus American/API performances. - This is ACEAs first attempt at a global spec.
    * E7 Euro 4 engines - exhaust after treatment (EGR / SCR)
    Part / full synthetic oils:
    * E4 Higher performance and longer extended drain
    * E6 Euro 4 specification - low SAPS for vehicles with PDF (see below)
    New low SAPS (Sulphated Ash, Phosphorous, Sulphur)
    This oil is a recent introduction for diesel engines fitted with a DPF (Diesel particulate filter). This is effectively a filter unit in the exhaust that takes out the microscopic soot particles. If you don't use a proper low SAPS oil, then the additives can block the filter with ash, which is a bit like putting a potato up your exhaust! New filters are pricey - £1500 isn't unusual.
    * C1 Low SAPS (0.5% ash) fuel efficient
    * C2 Mid SAPS (0.8% ash) fuel efficient, performance
    * C3 Mid SAPS (0.8% ash)
    Many OEM are now using their own specifications to capture this spec. eg. Mercedes 229.31/51, BMW Longlife 04, VW 507 00 etc.
    There is also a trend now towards manufacturers requiring their own specifications - in this case the OEM specification is the one that needs to be adhered to. If it says BMW Longlife 04, the oil must say this on the pack to be suitable for use
  6. catalin19841
    catalin19841 1st Gear Member
    7 Sep 2009
    Audi A6 3tdi 4f2
    Buna ziua, sunt posesorul unui audi A6 3 litri quattro 2007 ajutati-ma si pe mine va rog.
    Nu stiu cand s-a facut ultimul schimb la ulei si intentionez sa-i pun ulei Castrol Long Life. Poate cineva stie exact ce ulei trebuie sa pun. Multumesc frumos.
    Ultima editare de un moderator: 6 Iul 2011
  7. Dr. Gabriel
    Dr. Gabriel Audi Expert
    26 Iun 2010
    A6,1.8T AWT,2001
    Masina ta are DPF ? (filtru de particule) ?
  8. alex100145 Bronze Member
    3 Mai 2009
    resita
    Audi A4,BKE,1.9TDI PD 116 CP
    Ce-mi recomanzi la Audi a4 1.9 tdi pompe duze,mersi
  9. tiberius_roman
    tiberius_roman 4th Gear Member
    20 Aug 2009
    Audi
    Filtru de particule are 90% ii 2007. La Audi la reprez recomanda Long Life 3 Castrol SLX 5w30 sau Long Life III de fabrica.
    Daca nu are filtru de particule LongLife2 - de fabrica!
  10. Dr. Gabriel
    26 Iun 2010
    A6,1.8T AWT,2001
    @Alex100145 . In principiu ti-as recomanda MOTUL SPECIFIC 505 01 vascozitate 5W40 . Nu inteleg de ce unii vor musai sa-si puna Long Life desi nu au filtru de particule si masinile nu-i obliga sa foloseasca Long Life. Mda...fiecare face ce vrea cu motorul lui . MAi trebuie sa traiasca si magazinele de piese auto si mecanicii. Eu iubesc si magazinele de piese si pe mecanici numai atunci cand imi fac intretinerea ...(ulei, filtre, etc...etc..) in rest ...
  11. alex100145 Bronze Member
    3 Mai 2009
    resita
    mersi pt. raspuns ,la audi mi-au recomandat Castro; 5w-40 ,eu am acum Mobil 1 ESP 507.00 o zi buna
  12. Dr. Gabriel
    26 Iun 2010
    A6,1.8T AWT,2001
    Un coleg de pe forum cu un 2.5 TDI mi-a cerut parerea despre un ulei si eu i-am recomandat VW 505 01 pentru ca el nici nu-si stia norma de VW Din cate stiam eu, la 2.5 TDI pentru interval fix de schimb se foloseste 505 01 si pentru LL se foloseste 506 01 . Voi cei cu 2.5-uri ce parere aveti ?
  13. tucudean87
    tucudean87 Platinum Member
    3 Mai 2009
    Jack, la motorul de 2.5 TDI norma este 505.00 pt interval fix, pt ca motorul nu este cu pompe duse.
  14. mr_x4you 4th Gear Member
    13 Iun 2011
    A6 2.5 TDI 2002
    In carte scrie pentru long life 506.00 si pentru interval fix 505.00. Motorul de 2.5 nu PD, e cu pompa distribuitoare.
  15. Dr. Gabriel
    26 Iun 2010
    A6,1.8T AWT,2001
    Din cate stiam eu motoarele de 2.5 TDI din cauza problemelor cu axele cu came au recomandat uleiuri cu 01 in coada pentru PD desi ele nu sunt PD. Oricum un ulei pentru PD este facut sa mearga si pentru NON PD deci daca pune din ala nu este nici o problema. Stiam ca la aceste motoare sunt niste schepsisuri ....de aceea am intrebat. Sa inteleg ca la vo in carti scrie clar 505 00 pentru FIX si 506 00 pentru LL. Ok ?
  16. mr_x4you 4th Gear Member
    13 Iun 2011
    A6 2.5 TDI 2002
  17. Dr. Gabriel
    26 Iun 2010
    A6,1.8T AWT,2001
    Da, da...nr x4you ...adica scrie in carte la tine VW 505 00 interval fix si 506 00 pentru L.L ?
  18. mr_x4you 4th Gear Member
    13 Iun 2011
    A6 2.5 TDI 2002
    Da da, adica am raspuns la intrebare, asa e cum ai scris si tu. Am pus si un atasament extras din ELSA.
  19. lxl
    lxl Gold Member
    27 Ian 2009
    Elsa nu-i cartea masinii, ai pus-o frate:sex:.
  20. mr_x4you 4th Gear Member
    13 Iun 2011
    A6 2.5 TDI 2002
    E manualul de service :) Daca si aia mint acolo... In carte sigur scrie 506.00 pt LL, scanez si pe aia daca trebuie. :D
