  1. Florin Sandu
    Florin Sandu Banned
    26 Mai 2008
    Audi A8 3.0 TDI QUATTRO, Audi A3 1,6 FSI
    sal,
    vad ca esti din Bucuresti, acest ulei se gaseste la orice magazin de piese auto. daca vrei da-mi un pm cu numarul tau si-ti spun eu de unde sa cumperi.
    poti sa cumperi si Castrol SLX 5W30, este acelasi ulei. SLX este denumirea veche iar mai nou se numeste Edge:thumbs-up:
  2. tid 2nd Gear Member
    7 Sep 2008
    ploiesti
    AUDI A6
    Tipul de ulei
    Am schimbat uleiul si mecanicul a spus ca cel mai bun ar fi castrol 5w30 (v50400/50700)dar in carte scie vw50601 .Oare am facut vreo gresala ? RECIZEZ CA MASINA ARE MOTOR DE 103kw m6s 2000cm3 BLB ,din2005 si daca poate cineva sa-mi spuna daca are PD accest motor .MULTUMESC .
  3. Vlad04NOZ
    Vlad04NOZ Gold Member
    20 Sep 2007
    Uleiul pe care l-a folosit mecanicul cand a facut ultima revizie+distributie la masina mea 1.9 TDI-PD este: Mobil Syst S Special V 5W-30
    Product Description
    Mobil Syst S Special V 5W-30 is a high performance low ash diesel engine oil using a synthetic based formulation. It is primarily intended for use in Volkswagen pump-jerk diesel engines where an oil approved by Volkswagen to their specification VW 505 01 is required.
    Features and Benefits
    Mobil Syst S Special V 5W-30 provides the following features and benefits:
    Suitable for all driving styles from stop/start city traffic to high speed motorway cruising
    Low viscosity gives fast oil flow on start up even when cold to help protect all parts of the engine against wear
    Synthetic based formulation provides excellent high temperature performance and protection
    Advanced formulation gives good dispersion of diesel soot and keeps engines cleaner
    Low viscosity aids fuel economy and emissions reduction
    Applications
    Volkswagen TDI pump jerk engines used in many Volkswagen models for oil drain intervals of 15,000 km/1 year
    Other Volkswagen diesel engines according to recommendation.
    Ford Galaxy 1.9l Turbodiesel where an oil of Ford WSS-M2C917-A quality is required
    Suitable for use in other diesel engined vehicles where performance and viscosity grade are appropriate
    Asta am gasit despre ulei pe site-ul de la Mobil 1, asta sigur e recomandat pt VW motoare PD , pana acum am facut vreo 1000 - 1500 de km cu ea si pana acum merge ok, porneste la sfert dimineata la 8-9 grade... ;)
    Ultima editare: 6 Noi 2008
  4. leo75 1st Gear Member
    15 Noi 2008
    Audi A4
    ulei motor a4 diesel 2001 1.9 Tdi pompe-duse
    Am facut schimbul de ulei si in loc de Castrol Edge 5w 40 am pus Castrol Magnatec 5w 40. Din cate am inteles primul este bun pentru motoare diesel pompe duse cum am si eu avand specificatia VW 505.01 iar al doilea nu stiu pentru ce motoare diesel dar are specificatia VW 505.00. Va rog sa-mi spuneti daca este o problema pentru ca am folosit Magnatec-ul.
  5. leo
    leo 6th Gear Member
    4 Noi 2007
    Galați
    Nu stiu ce sa zic. In manualul de utilizare scrie la general ca se poate , iar in particular pentru motorul tau scrie ca merge 505.01. Atasez pozele!
  6. leo75 1st Gear Member
    15 Noi 2008
    Audi A4
    multumesc petru informatii, daca mai aveti ceva noutati mi-ar fi de folos
  7. Teko
    Teko Silver Member
    27 Iun 2008
    Ulei motor
    Trebuie sa corespunda normei VW 505.01 obligatoriu la PD!
    VW 505.00 este pentru non-PD!
    Functie de starea motorului (consuma ulei mai mult decat normal) poti folosi
    cu norma VW 506.01.
    De cand a aparut norma VW 507.00 (superior celor de sus), este cel mai indicat pentru ce ai tu.
    Eu folosesc Liqui-Moly Top Tec 4200-5W30, VW 507.00, cu setarea pe 15.000 km (dupa cum iti zice compu.bord) la conditiile din RO.
    Parerea mea: foloseste un ulei ORIGINAL cu una din normele VW pentru PD.
    Peste 50% din uleiurile comercializate la noi sunt falsuri.
  8. Vlad04NOZ
    20 Sep 2007
    La mine mecanicul a folosit ulei Mobil 1 Special V (5 W40), atasez o poza cu cateva detalii despre ulei;)
  9. leo
    leo 6th Gear Member
    4 Noi 2007
    Galați
    Asa stiam si eu dar de ce in manualul de utilizare la Audi A4 B6 este totusi trecuta si norma 505.00!! Toate motoarele diesel de la B6 sunt pompe duse totusi in foto atasat de mine mai sus apare si aceasta norma. (uite-te si in manualul tau chiar daca e in germana)
    Ultima editare: 16 Noi 2008
  10. maybogdan82
    maybogdan82 3rd Gear Member
    27 Mai 2008
    Mangalia & Norvegia
    AUDI A6 4F 2.0 TDI Multitronic 140 hp
    Ulei motor
    Salut am un A4 8E din 2002,am cumparato in vara din Norvegia.Masina a circulat 200 km aici dupa ce a fost adusa restul in germania.Asta vara am fost in Romania in vacanta si i-am facut schimbul de ulei (Mobil) acum am aproape 10.000 km si as vrea sai fac iar schimbul dar vreau un ulei bun si nici nu stiu ce tip de ulei a avut cat a circulat in GERMANIA.Ce imi sugerati?Care ar fi cea mai buna solutie in acest caz.Urmatorul tip de ulei pe care il voi baga va ramane definitiv masina avea 76000km cand am cumparat-o iar acum am 91.500 km.Ah , si inca ceva cere e treaba cu PD si de unde stiu ca este.
  11. Teko
    Teko Silver Member
    27 Iun 2008
    Ulei motor
    Norma VW 505.01 este norma minima pentru PD, sintetic.
    Urmeaza VW 506.01 full sintetic.
    Din ratiuni ecologice a aparut VW 507.00, care deasemeni este tot sintetic dar
    nu full.
    Pentru PD, cel mai complet ulei este cel cu norma VW 506.01, full sintetic.
    Nu prea este ecologic si ca atare au dezvoltat norma VW 507.00, sa impace si
    capra si varza! Vorbim de uleiurile pentru motoare Diesel cu PD care sunt foarte
    bune si pentru non-PD dar nu si invers!
    www.liqui-moly.de
  12. A4***tdi 1st Gear Member
    2 Oct 2008
    Audi A4
    Cel mai bun ulei ptr. motorul Audi 1.9 TDI Pumpe Duse EURO 3, este CASTROL 0W30 LONGLIFE II, norma VW 506.01, full sintetic, recomandat de constructor ca ulei cu interval de service extins (longlife). Eu mi-am cumparat din Germania si se comercializeaza numai in bidon de 1 litru, baxul avand 11 litri.
    Ptr. service normal la 15000 km interval de schimb, se foloseste uleiul CASTROL TXT 5W40, norma VW 505.01.
    Ptr. motoarele VW TDI Pumpe Duse este obligatorie utilizarea unui ulei norma VW 505.01 sau 506.01, NEAPARAT ULTIMUL GRUP DE CIFRE SA FIE "01" !!!
    DoubleV apreciază asta.
  13. Teko
    Teko Silver Member
    27 Iun 2008
    Ce te faci daca pe acel bidon de Castrol scrie ca e "Made in UE" adica
    fabricat in ***** si ambalat in ***** ?
    Ce garantie ai ca este adevarat?
    Nu conteaza marca, important este : ce scrie pe eticheta sa fie si "inauntru".
    "NEAPARAT ULTIMUL GRUP DE CIFRE SA FIE "01" !!!"
    Asta era valabil pana a aparut norma VW 507.00 (vorbim pentru Diesel),
    adica LL 3 (ultima generatie).
    Ultima editare de un moderator: 27 Mai 2014
  14. A4***tdi 1st Gear Member
    2 Oct 2008
    Audi A4
    Ulei 1.9 TDI P-D
    Uleiul 507.00 nu :no: este destinat motoarelor TDI Pumpe Duse :readit:!!!
  15. leo
    leo 6th Gear Member
    4 Noi 2007
    Galați
    A4***tdi Ba da, este destinat si motoarelor TDI pompa-diuza mai ales pentru cele cu DPF.
    " Edge 5W-40 Turbo DieselCastrol
    Aplicabilitate :
    Castrol Edge Turbo Diesel a fost dezvoltat pentru a indeplini specificatiile VW & AUDI Diesel (VW 505.01). Este special conceput pentru utilizarea in motoare VW TDI echipate cu sisteme de injectie electronice (pompa-diuza)
    Acest produs nu trebuie folosit in modele PD echipate pentru intervale extinse de schimb VW Longlife (indicate de literele QG1 pe placuta VIN – a se vedea cartea tehnica pentru detalii), deoarece, un alt produs, Castrol Edge 5W-30, detine specificatiile pentru aceste autovehicule (VW 504.00, 507.00)
    Acest produs este recomandat a se utiliza la intervale de schimb la 15.000 Km sau anuale
    Specificati / Performante :
    » VW 505.01/ 505.00/ 502.00.
    » Ford WSS-M2C917-A
    » ACEA A3/B3/B4
    » API SL/CF "
    Sursa : http://www.gami2000.ro/produse-castrol-autoturisme.html
  16. Teko
    Teko Silver Member
    27 Iun 2008
    Ulei motor
    Norma VW 507.00 (MAC) si VW 504.00 (MAS) sunt ultima generatie de uleiuri pentru motoare, inclusiv MAC cu PD (euro3, euro4, etc.)
    Citeste te rog aici, dar insistent, pentru ca sunt f. interesante si utile : www.liqui-moly.de
    Acolo este un tabel f.interesant in care gasesti norme si coduri standardizate utilizate de toti producatorii de uleiuri pe marci auto.
    Cu acest tabel, functie de ce cod (A2, A3, B3,B4,etc.) scrie pe eticheta, putem descifra mai bine destinatia uleiurilor de motor indiferent de producator.
    Ultima editare: 17 Noi 2008
  17. Eduard
    Eduard 1st Gear Member
    11 Aug 2008
    Audi A4 2005, 1.9 TDI, 116CP
    Ce tip de ulei?
    Am un AUDI A4 din 2005 , 1.9 TDI, 8KE. Ce marca de ulei si ce tip se recomanda pentru masina. Am pus CASTROL 5W-40, si acum trebuie sa ii fac schimbul din nou. Am inteles de la mecanici ca nu e prea bun CASTROL. Ce recomandati? :meeting:
    Merci.
  18. alex.petrariu
    alex.petrariu Gold Member
    17 Noi 2007
    Intre mecanici parerile sunt impartite in legatura cu uleiul ! Majoritatea prefera Castrol,altii Mobil ! Nu am folosit Mobil pe masinile mele dar ce pot sa-ti spun e ca de uleiul Castrol sunt foarte multumit ! Pe A4 am pus 10W-60 si se comporta exemplar chiar si iarna la temperaturi de -12 grade !
  19. Rapier
    Rapier Gold Member
    22 Aug 2008
    Acum am apucat sa citesc si eu aici. Te corectez un pic. 2.5 TDi V6, nu este motor PD. Iar in carte sunt date specificatiile de ulei pentru toate tipurile de motorizari. Deci nu toate motorizarile diesel de la A4 B6 sunt PD.
  20. alex.petrariu
    17 Noi 2007
    Incearca o cautare pe www.oilshop.ro dupa codul motor si ai sa vezi ce ulei e recomandat !
