Vand Audi A4 B6 2.0 benzina cod motor ALT
Discuție în 'Vanzari Audi' creată de radu82, 5 Apr 2025.
  1. radu82
    radu82 4th Gear Member
    31 Ian 2008
    A4 2.0 ALT 2002
    Vand audiul meu, A4 B6 ALT, 2002.
    160.000 km.
    Masina in ultimii ani a stat in parcare subteerana (pana in anul trecut), pornita cam la 6 luni.
    In acest moment nu porneste (nu are eror in bord), trebuie o diagnoza, suspectez bujii sau pompa de benzina.
    Deoarece nu am folosit-o nu are ITP si nici asigurare.
    Se da si un set de jante S-line 18 inch si un ipad care este integrat si este vazut ca magazie de CD uri.
    Pret fix: 1.700 Euro (banii se scot si daca se desmembreaza sau la rabla)
    Raspund mai repede pe telefon: 0720000812
    Codurile de dotari:
    E0A = No special edition
    7A0 = Without CD changer/CD player
    4UE = Air bag for driver and front seat passenger
    6XD = Exterior mirrors: electrically adjustable/heated
    5SL = Left exterior mirror: load
    5RU = Right exterior mirror: convex (large viewing field)
    1KD = Disc brakes, rear
    J1L = Battery 280 A (60 Ah)
    1LB = Disc brakes, front
    1BA = Standard suspension/shock absorption
    3FA = Without roof insert (standard roof)
    5MG = Decorative inserts, burr-walnut
    7X1 = Park distance control
    4R5 = Power windows with comfort operation andcircuit breaker, mechanical window regulators rear
    F0A = No special purpose vehicle, standard equipment
    8GR = Alternator 150 A
    0G1 = Gearshift lever
    0YH = Weight range 8 installation control only, no requirement forecast
    0JF = Weight category front axle weight range 6
    T0F = 4-cylinder gasoline engine 2.0 L unit 06B.E (aluminum)
    3ND = Rear seat bench/backrest, unfolding
    8JH = Ellipsoidal headlight for driving on the right
    U2A = Instrument insert with km/h speedometer,radio-controlled clock, tachometer and trip odometer
    X0A = National sales program Germany
    1N1 = Power steering
    2PG = Steering wheel
    8Q1 = Headlight-range adjustment
    9Q2 = Multi-function display/on-board computerwith check control
    8Z5 = Not hot country
    MW2 = 4-cyl. gasoline engine 2.0 L/96 kW 20V with multi-point injection base engine is T0F
    7Q0 = Without navigation device
    C1W = Alloy wheels 6.5J x 16
    7K0 = Without tire pressure warning light
    4X3 = Side air bag front with curtain air bag
    2K1 = Reinforced bumpers
    6R1 = Leatherette gearshift boot
    3L3 = Manual height adjustment for front seats
    4KC = Side and rear windows in heat-insulatingglass
    3Y0 = Without roll-up sun screen
    4K4 = Radio remote controlled central locking
    5D1 = Carrier frequency 433.92 MHz-434.42 Mhz
    1SA = Without additional front underbody guard
    0GG = Emission standard EU4
    Q1A = Standard front seats
    4GH = Windshield in heat-insulating glass with sunshield
