Motor 1.6 benzina la A4 B5 - diverse probleme cauze si rezolvari
Discuție în 'Audi A4 B5 (1994 – 2001)' creată de markw, 5 Mai 2009.
  1. audi66
    You are showing us 2 different things.
    If you are looking for N112, item #8 in the second picture, it corresponds with item #14 in the first picture, not with #59.
    Now it seems ok to you ? :)
  2. Valdis 1st Gear Member
    30 Iun 2018
    Latvia
    Audi A4 B5 Facelift 1.6 ANA
    Thanks for reply.
    As I understand #14 in first picture actually is N156 (intake manifold change over valve) and it's not in second picture.
    #14 first image (N159) is for moving air flaps inside intake manifold. It's closer to main radiator.
    #59 first image (N112) is closer to cylinder 4 intake runner.
    Ultima editare: 30 Iun 2018
  3. Valdis 1st Gear Member
    30 Iun 2018
    Latvia
    Correct way is shown in second image. N112 side port is for kombi valve because it is vented to atmosphere while N112 is powered off.
    Other port is vacuum source from intake.
    The same for N156. Side port is for actuator for intake flaps.
    Actually both have the same VAG part number.
    Thanks for help.
    How much g/s this 1.6 ANA engine MAF normally should have at idle (864...896rpm)?
    Because short term fuel trim jumps around -15...0% (average 8%), long term 1.6...3.1%
  4. Roxanamaya 1st Gear Member
    14 Noi 2018
    Turda
    Audi A4,B5 1.6 benzina
    Imi puteți spune va rog cum se face reglajul pentru aprindere la un audi A4 B5 benzina motor 1.6 ? Am schimbat delcoul și nu mai pornește deloc.
    Citesti integral acest topic: http://www.clubaudi.ro/threads/camshaft-position-sensor-senzor-hall-motor-1-6-adp.7765/ si acesta: http://www.clubaudi.ro/threads/tura...-b5-benzina-probleme-cauze-si-rezolvari.8080/ si acesta: http://www.clubaudi.ro/threads/porn...b5-cu-motor-benzina-cauze-si-rezolvari.19465/ si acesta http://www.clubaudi.ro/threads/buji...benzina-la-a4-b5-probleme-si-rezolvari.25253/ si mai ales acest topic, unde ai scris, il citesti integral
    Daca dupa tot ce ai citit tot nu reusesti sa faci ce trebuia, te sfatuiesc sa mergi la un bun mecanic auto.
    Inca ceva: te rog, sa modifici/completezi profilul tau cu masina ce o detii (in speta Audi), adica: tipul masinii, model, an de fabricatie, tipul motor/capacitate cilindrica si obligatoriu cod motor pentru ca data viitoare, daca mai pui intrebari, sa nu stam sa ghicim despre ce tip de masina si motorizare vorbesti. Uita-te la profilul meu si ai sa intelegi, cum trebuie sa arate si profilul tau. Multumesc.
  6. Adelin2042
    Adelin2042 3rd Gear Member
    22 Mai 2017
    Râmnicu Vâlcea
    Audi A4 b5 Sedan, 1.6 AHL , 1999
    Salutare ! Mi-a aparut un zgomot in zona galeriei de admisie ( un tacanit) care la relanti se aude usor si in turatie se intensifica, se aude foarte urat. Pot face ceva in afara sa schimb galeria de admisie ? Gasesc doar SH pe la 200 lei dar cine stie daca este buna...Se poate repara ceva ? Mersi !
    De unde stii ca nu este axa came defecta si de unde stii ca are legatura cu admisia ? Poate ai supape indoite. Mergi la mecanic si lasa supozitiile si intrebarile. Pe ghicite nu stie nimeni. Bafta.
  8. Adelin2042
    22 Mai 2017
    Râmnicu Vâlcea
    Stiu sigur ca e din galeria de admisie. Ideea e ca nu stiu daca se poate repara sau trebuie neaaparat alta.
  9. audi66
    Pai, daca tu stii sigur. Atunci ti-ai raspuns singur la intrebare, admisie noua.
  10. Adelin2042
    22 Mai 2017
    Râmnicu Vâlcea
    Unde sa găsesc admisie noua la mașina din 98’?
    La magazine de piese auto si chiar la reprezentanta ca doar nu la cofetarie. Exista dar trebuie sa platesti pretul cerut. Tine cont faptul ca si internetul la ora actuala este infinit si exista de cumparat ce vrei, inclusiv se pot fabrica orice componente auto indiferent de anul fabricatie (exista copii dupa schemele si matritele originale) dar repet, trebuie sa platesti pretul cerut.
  12. audi66
    Daca si-ar trece codul motor in profil, poate ar primi si un link.
  13. Adelin2042
    22 Mai 2017
    Râmnicu Vâlcea
    Codul este AHL, imi cer scuze ca am omis asta. M-ar ajuta mult un link. Va multumesc !
  14. audi66
    Tu esti sigur de ce zici ?
    Tocmai ma uitam la admisia ta si este o simpla bucata de metal, ce s-ar putea strica la ea ?
  15. Adelin2042
    22 Mai 2017
    Râmnicu Vâlcea
    Da. Nu este de metal la AHL, este de plastic si din cate stiu are niste clapete in ea care produc acel zgomot. Credeam ca a mai intampinat cineva aceasta problema, de asta am intrebat .
  16. audi66
    Imediat ma uit mai bine si revin cu un cod pentru admisie si eventual vreun kit de reparatie daca exista.
  17. Adelin2042
    22 Mai 2017
    Râmnicu Vâlcea
    Ok, mulțumesc.
  18. Eduard89 1st Gear Member
    5 Feb 2019
    Hunedoara
    AUDI a4,B5 , 1.6 ALZ(102CP), 2002
    Salutare tuturor.intampin si eu probleme cu 1.6 alz-ul(an 2002) asta,dupa citite sincer nu prea imi dau seama ce ar putea avea. Voi expune jos exact cum se manifesta:
    1.Dimineata la prima cheie,sta exat la 900 rpm de fiecare data,o las 2 min sa mearga ,o opresc i dau cheie iarasi porneste socul ,sta turata 10-15 sec isi revine la turatia normala.
    2.Relantiul fluctuaza usor,indiferent de temperatura de afara,nu scoate gram de fum pana nu atinge 90C,indiferent cat e de turata(pe loc sau mers(,ei bine,cand atinge apa la 90C,daca stau la semafor 40-50 sec,incepe sa scoata fum(albastru,negru).De fiecare data am cate -6 bujii la mine sa le tot schimb,imi uda bujia de cel putin 5 -6 ori pe zii la stationare.Pe fiecare cilindru bujia este neagra,chiar daca o pun noua,dupa 1 ora de mers,depuneri si neagra,doar pe cilindru 3 o uda foarte repede,acolo o schimb cel mai des(zilnic 3-4 ori).
    Pana acuma schimbat asa: Senzor temperatura,ulei si filtre,termostat,fise,bobina,bujii,furtun caze carter (fiind rupt in 3 locuri).
    ceea ce este ciudat,pun bujie NOUA,dau la automat,porneste motorul si de multe ori o uda in interval de secunde si gata,fum dupa mine plus mers in 3 pistoane.(daca o las la relanti,10 minute,e gata,mers 3 pistoane,bujia uda..schimb bag alta,de asemenea tot 10 minute maxim la fel,)
    Pe tester erorile date sunt: 3 testere diferite: 1. EGR 2. Clapeta acceleratie, 3, pompa aer secundar.
    daca cineva s-a lovit de aceiasi problema,va rog sa imi spuneti ca nu stiu ce sa i mai fac,din cauza ca imi uda bujia la Cilindru 3,uleiu de fiecare data e negru.(numai zic
    Va rog sa ma iertati pentru deranj.
    Ultima editare: 5 Feb 2019
  19. mp marius 1st Gear Member
    8 Feb 2014
    Audi A4 B5 ANA, 1.6 , 1999
    Buna ziua.
    De cand a trecut iarna intampin si eu o problema asemanatoare la A4 b5 1.6 ANA din 2000. Cand motorul este rece nu scoate fum dar daca a ajuns la 90 de grade si stau putin la semafor sau in trafic scoate destul de mult fum albastru. Ati reusit cumva sa depistati problema ?
    Va multumesc
  20. audi66
    Probabil semering si/sau supape.
    Cat ulei iti consuma ?
    remmy apreciază asta.
